Keith Browning Posted August 2, 2011 Share Posted August 2, 2011 This is a truck I replaced the main FEAD belt tensioner and belt on a couple of weeks ago. Trucks shows up today with no power assist for braking or the steering. I only had time for a quick inspection but all parts appear in-tact and the belt is fine. Then I noticed the large fluid supply line that goes from the reservoir to the pump was collapsed with the truck running. I wonder what I am going to find. Quote Link to comment Share on other sites More sharing options...
joshbuys Posted August 2, 2011 Share Posted August 2, 2011 Does it "suck" the pedal to the floor when pressing the pedal? I've seen this a couple times with a bad hydro-boost, it'll also wipe out a new pump in a hurry! Never noticed the collapsed supply line to the pump though. The one's I've seen were older, 7.3's and early 6.0's. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted August 2, 2011 Author Share Posted August 2, 2011 No, you get nothing from the systems. A rock hard brake pedal and a Pop-eye steering wheel. I am thinking the only thing it has to be is a blockage in the reservoir at the supply fitting but I cant imagine what. Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted August 2, 2011 Share Posted August 2, 2011 Quote Link to comment Share on other sites More sharing options...
DieselD Posted August 2, 2011 Share Posted August 2, 2011 check the lines at the hydro(the ones you pop off for cab removal) I had one similar came in after someone else pulled the cab. The lines where installed backwards causing all kinds of wacky issues. Quote Link to comment Share on other sites More sharing options...
lmorris Posted August 2, 2011 Share Posted August 2, 2011 I put one back together that the other tech took apart, I didn't notice the plug he put into the supply line. Same concerns as yours. I would go with the blockage idea. I noticed that the fluid would not flow in the res. when it was running. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted August 2, 2011 Author Share Posted August 2, 2011 Oddly, the fluid is moving in the res but not like a flow but rather a bubbly kind of action but without the air. The collapsed line is that has my attention. Quote Link to comment Share on other sites More sharing options...
cbriggs Posted August 10, 2011 Share Posted August 10, 2011 Not sure on an 08, but the 05 style has a filter screen in the reservoir. I have seen them get restricted and make pump do weird things, including make bubbles in the reservoir. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted August 10, 2011 Author Share Posted August 10, 2011 I had taken the reservoir out and found nothing major in it that could cause a restriction. There is no mention of a filter screen in the WSM but I suspect there may be one. After checking the hose for damage I stuck my thumb on the hose with the engine running and got some good suction. That hose was in good condition so it, was not the issue. After washing out the bottle I reinstalled it and I then had power assist and the hose was not collapsing. However the pump was making a of buzzing. The customer declined the repair and took the truck. Where to I have no idea. Quote Link to comment Share on other sites More sharing options...
