robp823 Posted September 29, 2011 Share Posted September 29, 2011 Have and 03 duramax,no codes,has a white haze at idle and under heavy load has lots of black smoke.As you go through the rpm range it almost sounds like a lifter tap.The only thing i was able to do with the scan tool at hand was check the balance rates of the injectors.Cyl #8 was at -5.03.Im wandering if that lifter tap sound im hearing is actually a fuel knock.Anyone have expirience with duramax? Quote Link to comment Share on other sites More sharing options...
Mbl35 Posted September 29, 2011 Share Posted September 29, 2011 It's a bit of work but maybe if you swap injectors and see if the -5.03 follows. Do you have the adapter to test compression? Quote Link to comment Share on other sites More sharing options...
robp823 Posted September 29, 2011 Author Share Posted September 29, 2011 nada dont have a compression adaptor.-5.03 sounds like an injector thats letting to much fuel go but could be wrong.A compression test would prolly be best. Quote Link to comment Share on other sites More sharing options...
cbriggs Posted October 2, 2011 Share Posted October 2, 2011 Injectors are a problem on these engines.If you call gm they will tell you to do all 8, and they are not at all cheap. Quote Link to comment Share on other sites More sharing options...
djmiller Posted December 1, 2011 Share Posted December 1, 2011 Early d-max injectors were kinda junky. GM gave em special coverage up to 300K. Balance rate over 4 in either direction - give 'er an 8 pack. Quote Link to comment Share on other sites More sharing options...
Mbl35 Posted December 2, 2011 Share Posted December 2, 2011 Also from what i understand on that year it is possible for a cup to come loose and come out with an injector when removing it. Quote Link to comment Share on other sites More sharing options...
