Engine Water Pump
I didn't look at the time specifically. I did look at the WSM procedure, then the truck, then the WSM procedure and then the truck. I left the lower shroud in and the stator bolted to the engine. Man, there are a lot of hoses in the engine compartment huh?
  • 1 year later...
Did you guys use new bolts for the water pump? do you realy need to replace them as it tells you to do in the wsm? they are usa stock which mean 7-10 days for me in Canada.
