Bruce Amacker Posted October 2, 2013 Share Posted October 2, 2013 I can't believe it hasn't been done yet. And probably won't be for fear of safety concerns...... Quote Link to comment Share on other sites More sharing options...
Chase Posted October 2, 2013 Share Posted October 2, 2013 You're probably right Bruce. Quote Link to comment Share on other sites More sharing options...
Aaron Posted October 5, 2013 Share Posted October 5, 2013 I trigger the remote start on my 6.4 truck before I shut the key off in the off chance I need to walk away immediately after arrival at my destination. Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted October 5, 2013 Share Posted October 5, 2013 Now that's thinkin' with your dipstick Jimmy! And everybody thinks your just another pretty face. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted October 5, 2013 Share Posted October 5, 2013 Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted October 5, 2013 Share Posted October 5, 2013 LOL Quote Link to comment Share on other sites More sharing options...
Aaron Posted October 5, 2013 Share Posted October 5, 2013 For those unaware, if you hit the remote start button when your truck is already running it stays running when you pull the key out. This is the old style command start system, not the integrated one on the new trucks. Apparently you can do it with the integrated system too, I'm just not sure how. Quote Link to comment Share on other sites More sharing options...
DieselD Posted October 8, 2013 Author Share Posted October 8, 2013 I have tried to keep mine running with the intergrated system but have yet to fiqure it out. I dont use it often enough in the raptor to have spent much time researching if its possible Quote Link to comment Share on other sites More sharing options...
Aaron Posted October 8, 2013 Share Posted October 8, 2013 Apparently you have to lock the doors twice, then hit the button twice. I seem to recall reading it on the internets. Quote Link to comment Share on other sites More sharing options...
Steve Mutter Posted December 8, 2013 Share Posted December 8, 2013 I have a 2011 f-550 right now that has a failed turbo. There is lots of play in the wheel and oil leaking into the scr system. I went to get approval for an scr system and they denied it telling me that it does not damage the dpf like in the 6.4's. I was told to remove the whole scr and stand it on end to let the oil drain out, then slowly get the engine to operating temp and then perform a active re gen to burn off oil in the exhaust. Has anyone else been told his by hotline? I can't believe that this is a acceptable repair. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted December 8, 2013 Share Posted December 8, 2013 The answer is that big submarine under the truck is not serviceable and costs too much money to just replace. It probably makes sense to clean it up and see what happens but I am sure there is a threshold where too much oil is simply too much. If it's just a little oil it will probably be okay.I would think that if it looks like this, it's probably done or it won't last very long. Quote Link to comment Share on other sites More sharing options...
Aaron Posted December 9, 2013 Share Posted December 9, 2013 It's gonna be awesome when you do it though. Make sure you film it lol Quote Link to comment Share on other sites More sharing options...
DieselD Posted December 9, 2013 Author Share Posted December 9, 2013 I have had yet another turbo take a dump...46k miles on this Quote Link to comment Share on other sites More sharing options...
mrbudge Posted December 9, 2013 Share Posted December 9, 2013 I have a 2011 f-550 right now that has a failed turbo. There is lots of play in the wheel and oil leaking into the scr system. I went to get approval for an scr system and they denied it telling me that it does not damage the dpf like in the 6.4's. I was told to remove the whole scr and stand it on end to let the oil drain out, then slowly get the engine to operating temp and then perform a active re gen to burn off oil in the exhaust. Has anyone else been told his by hotline? I can't believe that this is a acceptable repair. If Ford says cleaning oil contaminated clutches with brake kleen is ok, I guess performing an oil drain on an scr system is ok too. Hey, maybe wash it out with brake kleen too! Good luck in getting an active regen to complete today, -28 deg. Quote Link to comment Share on other sites More sharing options...
Steve Mutter Posted December 11, 2013 Share Posted December 11, 2013 Good luck in getting an active regen to complete today, -28 deg. Ya it should be fun trying to get this thing hot, Forecast does not look good for the week. The prior approval people also noted if there procedure was not followed the scr system may become damaged. Nice eh Quote Link to comment Share on other sites More sharing options...
Aaron Posted December 11, 2013 Share Posted December 11, 2013 A balmy -11 here today. -15 overnight. Better dig out my test FICM for tomorrow's tow ins and order up about a dozen or so batteries. Quote Link to comment Share on other sites More sharing options...
kbomb2788 Posted March 31, 2014 Share Posted March 31, 2014 From what I understand with 6.7L turbos, aside from tight location, is the reason they fail is cause if over spinning, most of the once I have done are work trucks that either have a heavy box or tire a goose neck. One of the reasons of new turbo on 15 superduty Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted March 31, 2014 Share Posted March 31, 2014 I did another turbo last week. Dumped a little oil in the exhaust so I just wiped it out with a rag and never told anyone about it. It's still sitting on my workbench. If they don't call it back for warranty (just a core) I'm going to disassemble it and take pics. Looks pretty close to a 6.0 turbo as far as disassembly. VGT solenoid has to be identical. Quote Link to comment Share on other sites More sharing options...
DieselD Posted June 9, 2014 Author Share Posted June 9, 2014 Im running out of tally space on my wall for these damn things. Had another turbo failure over the weekend, this particular truck has already had 2 turbos replaced and this will be its third turbo in 88k miles Quote Link to comment Share on other sites More sharing options...
lmorris Posted June 10, 2014 Share Posted June 10, 2014 I did another turbo last week. Dumped a little oil in the exhaust so I just wiped it out with a rag and never told anyone about it. We were told that oil or coolant in the SCR is no longer grounds for replacement, as they don't get messed up like the 6.4L DPF does. Quote Link to comment Share on other sites More sharing options...
Steve Mutter Posted June 11, 2014 Share Posted June 11, 2014 Hard to believe but that's their stance on these types of failures Quote Link to comment Share on other sites More sharing options...
