ford1664 Posted December 15, 2011 Share Posted December 15, 2011 what are you guys charging retail time to change the complete system? Quote Link to comment Share on other sites More sharing options...
Bruce Amacker Posted December 15, 2011 Share Posted December 15, 2011 Wow, I've been waiting for one of these. I assume you have one in the shop? Is it CP or insurance? Please keep us informed on what you do with it. Thanks! Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted December 15, 2011 Share Posted December 15, 2011 what are you guys charging retail time to change the complete system? I just completed a 6.7L that had water dumped into the fuel tank by vandals. Like water, DEF contamination is treated similarly as far as the repairs required. You will be replacing the entire fuel system and dropping the fuel tank to clean it. Mine was an insurance job and paid about 20 hours. With parts the bill came to about $8900 Quote Link to comment Share on other sites More sharing options...
ford1664 Posted December 15, 2011 Author Share Posted December 15, 2011 figured about 20 hours, (warranty time + 30% i got 21). yeah got one here in the shop now, parts quoted right now is around $9700. customer is going to call insurance company and see if they will cover it. Quote Link to comment Share on other sites More sharing options...
lmorris Posted December 15, 2011 Share Posted December 15, 2011 I didn't think insurance companies covered stupidity. Quote Link to comment Share on other sites More sharing options...
Fordracer Posted December 16, 2011 Share Posted December 16, 2011 I had my first 6.7 with gas in it a couple days ago. The guy filled up his truck and went to Home Depot and went back to his shop and then he got to thinking he might of put gas in it and called us and he said it's still running outside. We told him to shut it off and tow it in. When I get one with gas in the tank I use a diesel fuel hydrometer to see how much diesel is in the gas. Pure gas will not float the bulb and the more diesel that's in the gas the more it floats. If it doesn't float we will put the gas in employees cars. Well this didn't float so it was close to pure gas and it actually ran. I drained the tank, flushed the lines, and replaced the fuel filters. The thing actually started and runs fine. Quote Link to comment Share on other sites More sharing options...
jimmy57 Posted December 16, 2011 Share Posted December 16, 2011 I saw a guy on a cell phone pumping gasoline into his Chebby with D'max. He was putting nozzle back into pump when I noticed the bazooka tailpipe and knew it was a D'max. I told him and told him not to run it but he got in a drove off. I'm thinking the birth rate is going to fall because some people can't stay off cell phone long enough to do an f'in thing right. I haven't seen that truck on the side of the road but unfortunately those kind of things happen too rarely. Quote Link to comment Share on other sites More sharing options...
ford1664 Posted December 21, 2011 Author Share Posted December 21, 2011 when it rains it pours! now have another superdoody (2008) with fuel system contamination, removed cab and removed pump to inspect, found pump rusted inside, another retail job, woohoo! Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted December 21, 2011 Share Posted December 21, 2011 when it rains it pours! now have another superdoody (2008) with fuel system contamination, removed cab and removed pump to inspect, found pump rusted inside, another retail job, woohoo! Need to be careful on those. Removing the banjo bolts at the fuel cooler and inspecting them and the lines will show corrosion if water is an issue. Reason being is that once you have the cab off and access the pump only to discover it is no longer a warrantyable repair... Quote Link to comment Share on other sites More sharing options...
ford1664 Posted December 21, 2011 Author Share Posted December 21, 2011 ya, we talked to the customer before i pulled the cab, that if we found any rust or signs of water that it is not warrantable, he agreed to our terms and got his signature so off with the cab and pulled the pump. Quote Link to comment Share on other sites More sharing options...
robsmth41 Posted December 27, 2011 Share Posted December 27, 2011 we just finished up a customer pay 6.4 fuel contamination. put 20 in gas on top of roughly 5 gallons of diesel. drove the truck about 150 miles like that, then got the CEL and it died. showed up here running rough. i ran him through all the scenarios and possibilities, got his john hancock and ended up being around 8400 total. at the same time we had another 08 running rough and dying. manual FP test showed 4000 psi max. secondary housing looked like a silt pond on the bottom. another dealership just put a long block and fuel system in less than 12,000 miles ago. according to the story in the warranty write up there was no evidence of cleaning the fuel tank or flushing the lines after the engine was installed....we fought for the customer as he's a very good guy and a damn hard working contractor, but ford denied CLP, so the customer is going after the last dealership that worked on it....cant say i blame him Quote Link to comment Share on other sites More sharing options...
Aaron Posted January 12, 2012 Share Posted January 12, 2012 I had my first 6.7 with gas in it a couple days ago. The guy filled up his truck and went to Home Depot and went back to his shop and then he got to thinking he might of put gas in it and called us and he said it's still running outside. We told him to shut it off and tow it in. When I get one with gas in the tank I use a diesel fuel hydrometer to see how much diesel is in the gas. Pure gas will not float the bulb and the more diesel that's in the gas the more it floats. If it doesn't float we will put the gas in employees cars. Well this didn't float so it was close to pure gas and it actually ran. I drained the tank, flushed the lines, and replaced the fuel filters. The thing actually started and runs fine. Did you file a CUDL? Terminate fuel system warranty? This is going to get jammed up someone else's ass at another dealer down the road, I'd bet. Truck starts losing injectors/a pump and nobody can determine the root cause... Quote Link to comment Share on other sites More sharing options...
Fordracer Posted January 13, 2012 Share Posted January 13, 2012 It's like pulling teeth to get the SM to file a CUDL report when they are a regular customer. But I know what you mean. Quote Link to comment Share on other sites More sharing options...
