Matt Saunoras Posted January 7, 2012 Share Posted January 7, 2012 We've got a windstar we use as shuttle van that's been running strange lately. It's the same one that we drove while the rear axles were recalled and it nearly killed our used car manager when the thing broke driving down the road. Now it will occassionally buck and surge just driving normally, seemingly no rhyme or reason, never does it at idle or brake torquing and no misfires showing up. It's definitely a CKP/CMP related concern. Every time it does it it'll boot you out of power balance. The other guy in the shop just recently did upper intake gaskets and an IAC, then when he found out it was a sync concern he put a cam and crank sensor in it. Since I got wind of it we've checked the PCM connector for water intrusion and drove it down the road with the alt unplugged. no water was found and unplugging the alt didn't make a difference either. Now this is the end of the road for normal diag I believe. Not one pid is showing anything abnormal other than an RPM drop when it happens. CMP_F never showed a thing. No other pids seem to be useful for this so I'm not sure what is next. I'm not even a little proficient with a scope but I've got a feeling I'm going to have to learn unless someone has an idea. The cold line was ice cold today, so no help from them. Anyone run across this before? I recently fixed a 500 with an engine harness that was doing the exact same thing but it atleast gave me a weird pip code to go by. I did find a 104 pin bob and since we've been slow I am probably gonna get the go ahead to give it a shot. Quote Link to comment Share on other sites More sharing options...
Mbl35 Posted January 7, 2012 Share Posted January 7, 2012 Possibly synchronizer concern? Loose pin connection somwhere? Quote Link to comment Share on other sites More sharing options...
Aaron Posted January 11, 2012 Share Posted January 11, 2012 if the axle fell out/broke on a vehicle i was driving, the likelihood of me wheelin' it again is pretty fuckin slim Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted January 11, 2012 Share Posted January 11, 2012 Oh, how I missed these words of wisdom. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted January 12, 2012 Author Share Posted January 12, 2012 I never did get a chance to look at the windbag. If I do I'll report back on what I find actually I'm getting my ass handed to me by another gas job right now. 08 F250 5.4 with a seemingly random but not so random miss + some cam codes. If I can't get it by tomorrow I'll make a post. I did use the vct cam timing oscilloscope feature today on IDS(yes I'm that desperate). That was interesting to say the least Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted January 27, 2012 Author Share Posted January 27, 2012 A coil fixed the windstar and a long block fixed the F250 I suspect the windstar was actually misfiring and powerbalance wasn't picking it up. Either that or RFI but I've never seen a coil pack cause RFI The F-250 was losing oil pressure only when really hot and the vct retardation must have been causing the miss. It would only start to miss when put into gear Quote Link to comment Share on other sites More sharing options...
cbriggs Posted January 27, 2012 Share Posted January 27, 2012 Quote: I suspect the windstar was actually misfiring and powerbalance wasn't picking it up. Either that or RFI but I've never seen a coil pack cause RFI I had an escape a few weeks ago with a coil causing so much rfi that it was causing the IC to shut down and restart while driving. Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted January 27, 2012 Share Posted January 27, 2012 The V-8 SHO Taurus were bad about RFI around the number 8 coil and it would zap the MAF and make the car run really odd. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted January 28, 2012 Author Share Posted January 28, 2012 yeah lincoln LS's are very bad for RFI. COPs and heater control valves mostly, they do some weird stuff Quote Link to comment Share on other sites More sharing options...
