Used Edge Evolution
I defer to anyone with engine tuner experience: A used Edge Evolution performance tuner that has been used to reprogram a truck that, well, let's say... the tuner will never see the truck again.
Can this tuner be re-used on another truck? I am not concerned with preserving any downloaded data.
  • 4 weeks later...
Keith, as long as the stock file from the Evolution was loaded back into the PCM on that same truck, you are good to go. The tuner's work this way: They copy the stock program, store it in the tuner, and upload a performance file into the PCM. To return to stock configuration you must have the same tuner, as it is VIN locked to that PCM, restore the stock program to the truck, and the tuner retrieve's the performance file to be used again and again :thumbup:
  • 4 weeks later...
