09 6.4l fuse 27 blows
im working on a 6.4l f350. every once and a while when goign to start it the dash lights just shuts off and truck does nothing. found when this happens fuse 27 blows. maybe does it out of 100 starts then it will keep doing it for about maybe 20 key cycles off to start and sometimes if you just let it sit a bit it will work fine. sometimes the fuse wont blow and the starter will just not turn untill you let it sit a bit. the no starter response started before the fuse blowing. when it wont start turn key to on and jump starter wire under hood fires right up. same as when fuse is blowing. putting in a new fuse and then turning key on and jumping starter it will not pop. i have removed the bjb and checked all the related wiring from under dash to the front grill and have found nothing. any suggestions on what to check?
I have seen numerous electrical shorts caused by the harness chaffing on the edges of the core support, near the front inside corners of the fender liners. Can usually see in there, but need to pull the fender liner to repair.
That's a big help. Noticed when pulling down there the test light will light indicating ground. All thanks to your help. Only problem now is Ford shows the wire that I find sorted is a.blue/white wire. One I find is a white/violet.
Do you know of a wiring labeling issue for this?
Like Chris said, it can happen on both sides of the core support. I usually just remove the 2 front fender liner bolts and pull back the front of the left and right fender liners to have a look see at the harnesses. It's like a mirror image on the other side of the truck. Posted Image
