03 Focus Stalls And Theft Light Goes Crazy
Mbl35
Another shop has me checking this out for them.
This 03 focus with a 2.3l stalls at times. When it runs the pats light flashes then stops then some times just stays on.
When you turn on the the a/c the theft light flashes instantly,
it will surge and stall. No codes in the pcm, koer pass, koeo pass. No codes in the IC, battery voltage high and low codes in the abs and rcm and clear out and don't reapear. No check engine light or any other on. I never came across this before.
All the grounds are good and powers, battery terminals are good. The shop replaced the transciever and disconnected the remote start that was on there. I did a wiggle test on the harness and it did'nt trigger anything.
This shop initially called me to program keys for a used computuer from a salvage yard. I explained to them that it wont work becuase a new blank pcm is needed and an IDS to even try to blank out the pcm that they got. And im not even sure that is possible anymore with the latest IDS versions.
I think they are right that it needs a pcm and they want to sell the customer a pcm from a company on ebay that puts all the info for you and you just got to program the keys-Is that possible Posted Image. I did that with a ficm and it worked out very good but im not sure about a pcm.
Also disconnected the alternator and still does it. It will do it when he a/c is off when you drive it.
Before they sell a pcm they want me to find out any other info on this. Anyone see this before?
If it is possible to program a pcm away from a vehicle then i will be programming the keys for them.
If anyone can run oasis-1fafp36z93w330529
Thanks Posted Image
Quote:
OASIS RESULT: 1FAFP36Z93W330529
USA: EN-US
29-FEBRUARY-2012 / 07:26:54 / FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION: 2003 FOCUS BODY STYLE: 4 DR WAGON SE ENGINE: 2.3L 4V PZEV
TRANSMISSION: 4 SPEED AUTO AXLE CODE: JJ ENGINE CALIBRATION: 3AK1PZ0A
PAINT COLOR: TWILIGHT BLUE C/C #2 PAINT CODE: MK RADIO
AXLE RATIO: 3.73 FINAL DRIVE RATIO WHEEL SIZE: 6.0 X 15" ALLOY ROAD WHLS-#1 FRONT TIRE: 195/60R15-S BSW
WARNING MESSAGES
VERIFY STATE REGISTRATION, VIN MAY BE ELIGIBLE FOR 15/150 CALIF PZEV EMISS WTY
ACCURATE REPAIR NOTIFICATIONS
NO ARN MESSAGES FOUND
GENERAL WARRANTY INFORMATION
WARRANTY START DATE: 11-DECEMBER-2003 BUILD DATE: 19-AUGUST-2003 SALE MILEAGE
OUTSTANDING FIELD SERVICE ACTIONS
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
Competitive make ESP part verification
0999 - EXPIRED
STANDARD DEDUCTIBLE: 100 USD OWNER NAME: . AUTOMOTIVE RENTALS INC OPTIONS:
EXPIRATION DATE: 11-DECEMBER-2008 DISTANCE: 100000 RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD CONTRACT SOLD BY: USA 49073 ESP CONTRACT START DATE: 11-DECEMBER-2003
0798 - USA 2002 NEW QUALITY FLEET CARE ONLY
STANDARD DEDUCTIBLE: 0 OWNER NAME: PEP BOYS OPTIONS:
EXPIRATION DATE: 11-DECEMBER-2023 DISTANCE: 999999 RENTAL: 0 UP TO 0 DAYS
TOWING: 0 CONTRACT SOLD BY: USA 49073 ESP CONTRACT START DATE: 11-DECEMBER-2003
OWNER OF VEHICLE MUST MATCH OWNER NAME ON OASIS FOR COVERAGE TO APPLY THIS UNIT ENROLLED IN QUALITY FLEET CARE. QFC PROGRAM TO BE USED FOR CENTRALIZED BILLING OF: CUSTOMER PAY: NON-WARRANTY AND NON-ESP REPAIRS MAINTENANCE SERVICES NOT COVERED BY ESP DEDUCTIBLES: WARRANTY AND ESP DEDUCTIBLES RENTAL: CHARGES BEYOND ESP COVERAGE, (UPGRADES OR DAYS) TOWING: CHARGES BEYOND WARRANTY OR ESP COVERAGE RETAIL REPAIR LAWS AND REQUIREMENTS APPLY. WHEN REPAIRS EXCEED $1 CONTACT: ROB NYSTROM FOR AUTHORIZATION AT: 215-430-9703 CHARGES ARE BILLED TO THE FLEET FOR PAYMENT BY QFC CLAIM INSTRUCTIONS/JOB AIDS AVAILABLE AT: www.QFC.FORD.COM QFC PROGRAM ASSISTANCE: 800-367-3221
WARRANTY REPAIR HISTORY
NO RECENT REPAIR HISTORY ON VEHICLE
Warranty history
Quote:
AWS Claim Key Time In Service Labor Hours Dealership DIST (Miles) Repair Date Prefix Base Suffix Doc
Details 11126243 19 2.6 LIGHTHOUSE FORD, LLC 13015 14-JUN-05 2M5Z 2B373 FA 002092C
Customer Comments ABS LIGHT IS ON
Tech Comments 13015 CK ABS LT. ON PERFORM SELF TEST RETIEVE CONTINUOUS CODES C1234 & C1233 LEFT & RIGHT FRONT W SPEED SENSORS MISSING SIGNALS,INSPECT CONNECTIONS AND FOR DAMAGE ON W S SENSORS AND ABS MODULE,NONE FOUND.R&I BATTERY & TRAY TO ACCESS ABS MODULE CONNECTION.PINPOINT TESTS F1,F2 SAYS IF NO DAMAGE REPLACE MODULE,ORDER PART.
Details 11156066 19 3.5 LIGHTHOUSE FORD, LLC 13015 14-JUN-05 3W4Z 12B579 AC 002092B
Customer Comments CHECK ENGINE LIGHT
Tech Comments 13015 CK ENGINE LT. ON PERFORM SELFT TEST RETRIEVE KOEO & KOEC CODES P0102,P0113,P0171,P0174,P0411 AND P0420.FOUD DAMAGED HARDSHELL CONNECTOR AND MASS AIR FLOW SENSOR CORROSION ORDER PART
Details 11985413 21 2.9 LIGHTHOUSE FORD, LLC 16841 17-AUG-05 4S4Z 5G232 CB 003229A
Customer Comments C S CHECK ENGINE LIGHT IS ON, WHEN YOU GIVE IS GAS HARD WILL PAUSE ON ACCEL
Tech Comments 16841 R T VECHICLE FOR CEL LIGHT AND NO POWER RETRIEVE CODES PO 411 PO420 FEELS CAT IS CLOG AGAIN RAN SSM TSB FOR CONCERNS REPLACE MIDDLE CONVERTER IN JUNE POSSIBLE FRT CAT IS THE PROBLEM RAN PINPONT TEST FOR PO411
Details 11850907 21 .6 LIGHTHOUSE FORD, LLC 16841 17-AUG-05 3S4Z 5E212 AE 003229C
Customer Comments RECENTLY REPLACED CATALYIC CONVERTER WAS CLOGGED AGAIN
Tech Comments CHECK AND REPLACE CATALYTIC CONVERTER
Details 14430547 32 1.3 LINCOLN OF BABYLON 40101 18-JUL-06 3S4Z 10849 EB 01702601
Customer Comments TRANSMISSION CONCERN CUST STATES FROM A ROLLING STOP CAR HAS A HARSH CLUNK OR BANG
Tech Comments TEST & VERIFY TRANSMISSION HUNTS UP & DOWN AT ABOUT 20MPH NOTICED UP SFIFT LIGHT ON IN DASH VEHICLE IS AUTOMATIC & NOT MANUEL CALLED HOT LINE NO HELP LAMP STAYS ON PCM/GEM MODULES ARE UNPLUGEDREMOVED DASK FUSE IT GOES OUT CK GROUNDS OK SUSP ECT CLUSTER ORDERED & INSTALLED CLUSTER SHIFT LIGHT OUT PROGRAM KEYS & ROAD TEST OK SHIFTS NORMAL AUTH 97587
Details 14420560 32 .8 LINCOLN OF BABYLON 40101 18-JUL-06 * * * 01702603
Customer Comments REAR DOOR LATCH DOOR LATCH CORROSION
Tech Comments COMPLETE RECALL 05S27 REAR DOOR LATCH CORROSION
Details 15805057 51 0 SAYVILLE FORD 79278 08-FEB-08 * 2002 * 53179904
Customer Comments CUSTOMER STATES:REPLACE WORN CRACKED REAR BRAKES
Tech Comments WORN OUT TECH FOUND REAR BRAKE SHOES WORN AND CRACKED. REPLACED REAR BRAKE SHOES. RESURFACED 1 DRUM AND REPLACED 2ND DRUM. NOTE BEARING IN DRUM CAME APART WHEN IT CAME OFF VEH. BEARING NON SERVICABLE. ONLY PART OF DRUM. ALSO ABS TONE RING NEEDED TO BE REPALCED. DID NOT COME WITH DRUM.
Details 15805058 51 0 SAYVILLE FORD 79278 08-FEB-08 * 17528 * 53179903
Customer Comments CUSTOMER STATES REPLACE WIPER BLADES WITH NEW
Tech Comments REPLACED WIPER BLADES WITH NEW.
Details 15805056 51 0 SAYVILLE FORD 79278 08-FEB-08 F8CZ 6731 AA 53179905
Customer Comments CUSTOMER STATES PERFORM OIL & FILTER CHANGE CHECK & SET ALL TIRE PRESSURES.
Tech Comments AS PER CUSTOMER REQUEST TIME OR MILEAGE PERFORMED OIL AND FILTER CHANGE SHOULD BE PERFORMED EVERY 3 MONTHS OR 3,000 MILES.
Details 15805060 51 0 SAYVILLE FORD 79278 08-FEB-08 5S4Z 11582 BB 53179901
Customer Comments CUSTOMER STATES:CHECK IGNITION LOCK KEEPS BINDING. WILL NOT TURN AT TIMES
Tech Comments TECH VERIFIED IGN LOCK BINDING. FOUND LOCK CYLINDER AND HOUSING NO GOOD. REPLACED LOCK CYLINDER AND HOUSING. RETESTED OK. NOTE ALL REPAIRS AUTH BY ROB NYSTROM PEP BOYS ON 2 8 08 10:18 AM. AUTH # 107227.
Details 15805055 51 0 SAYVILLE FORD 79278 08-FEB-08 * 7000 * 53179906
Customer Comments CUSTOMER STATES:PERFORM TRANSMISSION FLUID FLUSH SERVICE
Tech Comments PERFORMED TRANSMISSION FLUID FLUSH SERVICE
Details 15805059 51 0 SAYVILLE FORD 79278 08-FEB-08 6S4Z 17683 BA 53179902
Customer Comments CUSTOMER STATES:CHECK DRIVERS DOOR MIRROR BROKEN OFF. REPLACED MIRROR AS NECESSARY
Tech Comments REPLACED BROKEN DRIVERS DOOR POWER MIRROR ASSEMBLY
Details 16034808 55 0 SAYVILLE FORD 87506 19-MAY-08 5S4Z 5K484 AA 53625902
Customer Comments CUSTOMER STATES NOISE FROM FRONT END
Tech Comments VERIFY NOISE,REPLACE BOTH WORN FRONT SWAY BAR LINKS
Details 16049395 55 0 SAYVILLE FORD 87506 19-MAY-08 3S4Z 6758 AA 53625903
Customer Comments CUSTOMER STATES WHEN CAR IS WARM HEAR NOISE FROM ENGINE WHEN SHUTTING IT OFF
Tech Comments VERIFIED NOISE,NOISE FROM REAR OF ENGINE,REMOVE INTAKE MANIFOLD,FOUND CRACKED VACUUM HOSE,REPLACED VACUUM HOSE,HAD TO REMOVE STARTER TO ACCESS HOSE.NOTE THIS OPERATION IS THE SAME AS LINE ONE.SHOULD HAVE SUBMITTED UNDER QFC,NOT ESP
Details 16044427 55 0 SAYVILLE FORD 87506 19-MAY-08 1S7Z 9439 AA 53625901
Customer Comments CUSTOMER STATES WHEN CAR HAS BEEN RUNNING AND ENGINE IS WARM,THERE IS A WHINNING NOISE FROM R/F ENGINE AREA AND THE ENGINE SHUTS DOWN.
Tech Comments VERIFIED ENGINE STALLS WHEM WARM, HEARD NOISE FROM REAR OF ENGINE,FOUND VACUUM LINE BEHINE INTAKE,REMOVED STARTER AND INTAKE,REPLACE CRACKED VACUUM HOSE,RECHECKED,ALL OK
Detailed Vehicle Info
Quote:
GENERAL VEHICLE INFORMATION: (Related Claims)
VIN: 1FAFP36Z93W330529 Veh Line: C/AK - FOCUS [99-10] Eng Serial No: 310703172237
Model Year: 2003 Market Derived: F - FORD Body Shell: *
Veh Type: C Drive Code: C/A - 2 WHL L/H FRONT DRIVE Engine: C/GZ - 2.3L-4V DOHC EFI NA I4 GAS
Inv. Dealer: * Body Cab Style: C/FF -4 DOOR STATION WAGON Transmission: C/D2 - 4 SPD AUTO VANDYKE FN TRANS
Version/Series: * - [N/A]
Trace Eng Serial No:
---------1----------2---------3--------4---------5-----------6----------7---------8
01310703172237
Trace Trans Serial No:
A4920 14080332260361 3S4P 7000 AA
BUILD INFORMATION:
Region: NA - ########## Plant: AZ - WAYNE PLANT BUILD
Country: USA - ########## Prod Date: 19-AUG-2003
SALE INFORMATION:
Region: NA - ########## Selling Dealer: 113103 -*
Country: USA - ########## Selling Dlr St/Prov: NY
Buyer St/Prov: *
Arrival Date: 29-AUG-2003 Red Carpet Lease: 2
Sale Date: 11-DEC-2003 Fleet/Retail/Co. Lease: F
Warranty Start Date: 11-DEC-2003 Modified Vehicle: *
Orig Warranty Date: 11-DEC-2003 Reacquired Vehicle: * Vehicle Export Flag: N
VOC/EOC:
---------1---------2---------3---------4---------5---------6---------7---------8----------9----------
P363W330529 8 2 03G1199 OF E 2RA 38 CJ2 K5L 2 L 13E103 2 MK TH2 5 Z
1FAF9 7 L D 400A 9Z2NY
INSTALLED OPTION INFORMATION:
Air Conditioning: C/B - MANUAL AIR CONDITIONER GVW Code:
Alternator Amp Rating: 1 GVW Class Code: F
Audio Disk: * - [N/A] Instrumentation: AG - LOW SERIES ANALOG CLUSTER
Axle Ratio: EGAJB - 3.73 FINAL DRIVE RATIO Mirror(Driver Side): AD - DRIVER POWER MIRROR
Axle Type: * - [N/A] Mirror(Psngr Side): AD - PASS POWER CONVEX MIRROR
Battery Amp Rating: 2E Paint: PNMB8 - TWILIGHT BLUE C/C #2
Brake Code: * -[N/A] Power Antenna: * - [N/A]
Brake Code(Service): * -[N/A] Radio: D5 -
Calibration Code: 3AK1PZ0A Sound System: AA -LESS UPGRADED SOUND SYSTEM
Color(Accent): * - [N/A] Suspn Tandem Axle:
Color(Trim): 000HF - MED PARCHMENT Tire Brand: AG - GOODYEAR
Delivery Type: D Tire Size: D3GNZ - 195/60R 15T BSW
Driveshaft Code: * Traction Control: AA - LESS ANTI-SPIN TRACTION BRAKES
Front Seat: C/B - SEAT-INDIVIDUAL-L/B DRV/PASS Wheel Base:
Fuel Type: * -[N/A]
TIRE DOT INFORMATION:
LF: M6V9LNER???? RF: M6V9LNER3103
LR: M6V9LNER???? RR: M6V9LNER3103
LI: * RI: *
SPARE: PDP5H4ER2403
ESP INFORMATION: EMISSIONS INFORMATION:
ESP Code: G Emission Code: C/M - C/M
ESP Coverage(Miles): 100 Emission Cert Type: C
ESP Coverage(Time): 060 Emission Decal Suffix: KHG
ESP Plan Year: 2004 Engine Family: 3FMXV023VLC
ESP Signature Date: 11-DEC-2003
