Keith Browning Posted May 7, 2012 Share Posted May 7, 2012 I was asked a question that I don't know the answer to nor can I find one. What is the reason for/purpose for using spacers on exhaust manifold bolts? Quote Link to comment Share on other sites More sharing options...
Bruce Amacker Posted May 7, 2012 Share Posted May 7, 2012 Adding a spacer gives more physical length to the stud/bolt which translates to more clamping stretch. This allows more "give" or tolerance of the expansion and contraction present during heat cycles thus preventing the bolt from coming loose, allowing the gasket to leak, or snapping off from overstretch. Maybe the 4.6/5.4 need bigger spacers? Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted May 7, 2012 Author Share Posted May 7, 2012 Thank you Mr.A. I was thinking it was something like that... but then I thought we still see broken bolts on the diesels too! Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted May 9, 2012 Share Posted May 9, 2012 do you guys see a lot on the 6.0s? I've only ever run across one. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted May 9, 2012 Author Share Posted May 9, 2012 do you guys see a lot on the 6.0s? I've only ever run across one. Actually not many. If I see a broken manifold bolt on one it more than likely has rusted to the point of breaking or snapped trying to remove it. Quote Link to comment Share on other sites More sharing options...
blown99 Posted May 15, 2012 Share Posted May 15, 2012 Not on the 6.0's, I see them on the 7.3 engines, more so on the old body style. Quote Link to comment Share on other sites More sharing options...
