ktmlew Posted June 13, 2012 Share Posted June 13, 2012 Anyone help me out? 1FTSW31P03EB99000 01/03 f250 4X4 Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted June 13, 2012 Share Posted June 13, 2012 You ex-Ford techs are a PITA. OASIS RESULT: 1FTSW31P03EB99000 USA: EN-US 13-JUNE-2012 / 16:03:41 EST/ APP2 Local Time: 13-JUNE-2012 / 4:03:43 PM VEHICLE INFORMATION VEHICLE DESCRIPTION: 2003 F-SERIES BODY STYLE: F-350 CREW CAB 4X4 ENGINE: 6.0L DIESEL DI V8 TRANSMISSION: TORQSHIFT AXLE CODE: D1 ENGINE CALIBRATION PAINT COLOR: OXFORD WHITE WB C/C-W/B PAINT CODE: Z1 RADIO: ELETR PREM STRO/CSTE/DISC/CLK AXLE RATIO: 3.73 FINAL DRIVE RATIO WHEEL SIZE FRONT TIRE: LT265/75R-16E OWL A-T GROSS VEHICLE WEIGHT: 9900 LB. GVW NO WARNING MESSAGES FOUND FOR THIS VIN ACCURATE REPAIR NOTIFICATIONS ATTENTION TECHNICIANS AND SERVICE MANAGERS: BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 09-08-03 DON'T REPLACE A FICM ASSEMBLY WITHOUT FIRST REFERENCING 10-12-06 TO ENSURE OPTIMUM COOLING SYSTEM PERFORMANCE, REFER TO 09-08-05 GENERAL WARRANTY INFORMATION WARRANTY START DATE: 07-AUGUST-2003 BUILD DATE: 16-JANUARY-2003 SALE MILEAGE: 00082 OUTSTANDING FIELD SERVICE ACTIONS NO CAMPAIGN MESSAGE(S) FOUND EXTENDED COVERAGES NO ESP INFORMATION AVAILABLE WARRANTY REPAIR HISTORY NO RECENT REPAIR HISTORY ON VEHICLE Details 1515747 03B05 0 .7 HILBISH MOTOR CO 15 11-JUN-03 * * * 08794101 Customer Comments 03B05 ICP SENSOR REPLACEMENT Tech Comments REPLACED ICP SENSOR Details 1515746 03B06 0 .7 HILBISH MOTOR CO 15 11-JUN-03 * * * 08794102 Customer Comments 03B06 COLD OPERATION CALIBRATION ENHANCEMENT Tech Comments REPROGRAMMED PCM FICM AND TCM Details 3466103 2 3 .7 MOORESVILLE FORD 8158 14-OCT-03 * RECAL * 06628952 Customer Comments CUST STATES AT TIMES ERRATIC IDLE HUNTS UP & DOWN Tech Comments PCM PERFORM TSB 03 20 12 Details 3563766 2 3 12.8 MOORESVILLE FORD 8158 14-OCT-03 * 6007 * 06628951 Customer Comments TOW TO SHOP CUST STATES MAJOR COOLANT LEAK AT REAR OF ENGINE Tech Comments LEAK DIAG COOLANT LEAK VERIFIED COOLANT LEAK, PRESSURE TEST, R R FAN SHROUD, STATOR, TURBO, CES, INTAKE MANIFOLD AND OIL FILTER ADAPTER, BOLT LOOSE AT FRONT OF OIL FILTER ADAPTER NEAR COOLANT PASSAGE, INSPECT ORINGS, REASSEMBLE, CHANGE OIL FILTER AND OIL, STEAM CLEAN ENGINE Details 3367876 P01 3 0 MOORESVILLE FORD 8158 14-OCT-03 * MISC * 06628954 Customer Comments REFUND FOR TOW CHARGES Tech Comments REFUND FOR TOW CHARGES Details 8251929 04S15 15 .4 MOORESVILLE FORD 45005 26-OCT-04 * * * 08294052 Customer Comments PERFORM 04S15 Tech Comments RECALL COMPLETE RECALL Details 8251928 S07 15 9 MOORESVILLE FORD 45005 26-OCT-04 3C3Z 9C968 AA 08294051 Customer Comments VEHCILE WILL NOT START. ADVISE Tech Comments IPR HARD START NO START DIAGNOSTICS DIESEL ENGINE DIAGNOSI Details 14021032 59B01 35 .3 MOORESVILLE FORD 86267 19-JUN-06 * * * 01019653 Customer Comments PERFORM TEST DRIVE RECALL 59B01 Tech Comments TEST DRIVE CUSTOMER ASSURANCE TEST DRIVE REPLACE Details 14021031 06E17 35 .7 MOORESVILLE FORD 86267 19-JUN-06 * * * 01019652 Customer Comments PERFORM CONTROL MODULE RECALIBRATION RECALL 06E17 Tech Comments RECALL REPROGRAM PCM, TCM, AND FICM Details 14021030 E72 35 4.5 MOORESVILLE FORD 86267 19-JUN-06 4C3Z 9F452 A 01019651 Customer Comments C S HAS MISS AND HESITATES AND BLOWS BLACK SMOKE UNDERLOAD....CHECK AND ADVISE Tech Comments EGR ENGINE PERFORMANCE DIAGNOSTICS DIESEL ENGINE DIAGNOSIS Quote Link to comment Share on other sites More sharing options...
ktmlew Posted June 13, 2012 Author Share Posted June 13, 2012 Thank you! As I expected it hasn't seen a dealership for quite a while. Quote Link to comment Share on other sites More sharing options...
