Parts List Request
ktmlew
2003 F-250 4x4 prod date 01/03
VIN 1FTSW31P03EB99000 6.0L Auto
1. New HPOP
2. HPOP COVER
3. New IPR to CYA.
4. Hot-tank intake manifold.
5. Inspect EGR valve-replace as needed
6. Updated turbo oil drain tube.
7. Updated turbo oil supply tube?
8. New oil cooler
9. Iat 2 <price it's really clogged> already cleaned it but?
10. Gaskets?
11. EGR cooler hose?
I don't know what gaskets, hoses, bolts, o-rings, etc come with which kits?
1. New HPOP 3C3Z-9A543-AARM
2. HPOP COVER 3C3Z-9G805-AA (comes with new IPR installed)
3. New IPR to CYA. CM-5054 (but not needed if you're replacing the cover above)
5. Inspect EGR valve-replace as needed CX-2056
6. Updated turbo oil drain tube. 6C3Z-9T515-A
7. Updated turbo oil supply tube? 3C3Z-9T516-A
8. New oil cooler 3C3Z-6A642-CA
9. Iat 2 <price it's really clogged> already cleaned it but? DY-984
10. Gaskets? 3C3Z-9439-AA (Intake Gaskets)
11. EGR cooler hose? 3C3Z-9433-BJ (EGR Cooler Hose, "Donut" and turbo bolts)
And don't forget 3C3Z-9T288-AA which is the discharge tube too. I assume the purpose of this post is a request for part numbers.
You da man...I never did believe that shit they said about you...!!!
This site and it's members are the best. I always save this stuff for future use. Hopefully I can find a building to rent so I can do more of these. Only problem for me is my back really doesn't like doing this stuff cab-on...old age is a bitch.
OH REALLY??? What shit???
After doing the same job, so many times it gets a little repetitive, so I make it a habit of memorizing part numbers to help expedite the parts request/ordering process. For some reason, I find the 2003 versions of these engines to be more of a pain to wrench on than the later versions. It helps much more when you have an assistant standing outside to pass the heavy parts to (intake, turbo etc.). I use an old Focus seat cushion on top of the rad support to prevent my huevos from being crushed.
Shit they said was a joke...my dad was a huge agitator and loved that saying.
As for part numbers I kept a list I had laminated. Just gave it to parts guy and let him page me when he was ready.
