Steve Mutter Posted June 19, 2012 Share Posted June 19, 2012 I have a 97 7.3 that smoked black then stalled out. They are from out of town and the trucks passenger side bank has both melted pistons and cracked pistons. I have not inspected the drivers side but compression was good around 380 psi. I can't get the full story but this is a reman engine that has blown up a couple of times before. They tell me that they have had the passenger side head replaced already. I have inspected the injectors and did not find any cracked tips, I did find one injector had the upper o-ring with some damage. I have checked the fuel and it looks clear and free of water. What would cause just one bank to go down like this? Could the truck have had a leaking injector raising the oil level causing the engine to run on unmetered fuel ? Have you seen this before on the 7.3? any advice? Quote Link to comment Share on other sites More sharing options...
DieselD Posted June 20, 2012 Share Posted June 20, 2012 Have you checked for a tuner or chip yet? Quote Link to comment Share on other sites More sharing options...
