Keith Browning Posted June 21, 2012 Share Posted June 21, 2012 This is probably impotant to make note of. Jun 20 2012 4789 -6.7L - DIESEL EXHAUST FLUID (DEF) PETROLEUM CONTAMINATION DEF TEST STRIPS ARE NOW AVAILABLE FROM ROTUNDA UNDER PART # 328-00012 OR 328-44-863. THIS NEW TEST STRIP CAN BE USED TO DETECT PETROLEUM BASED CONTAMINATION WHEN DIAGNOSING DEF RELATED SYSTEM DTCS WHEN FLUID QUALITY CONCERNS ARE SUSPECTED. PC/ED IS IN THE PROCESS OF BEING UPDATE TO INCLUDE THE USE OF THE STRIPS. DEF SYSTEM FAILURES THAT ARE CAUSED BY PETROLEUM BASED CONTAMINATION WILL REQUIRE THE COMPLETE DEF SYSTEM TO BE REPLACED. CLEANING AND REUSE OF DEF SYSTEM COMPONENTS WILL RESULT IN REPEAT REPAIRS. THE NEW VEHICLE LIMITED WARRANTY DOES NOT PROVIDE COVERAGE, AND REPAIRS ARE NOT REIMBURSABLE UNDER WARRANTY, WHEN DAMAGE RESULTING FROM THE USE OF CONTAMINATED OR IMPROPER FLUIDS ARE USED. REFER TO THE WARRANTY AND POLICY MANUAL FOR ADDITIONAL INFORMATION. Quote Link to comment Share on other sites More sharing options...
