2003 F350 7.3
Truck has a surge or could be described as hunting at 40-60 km/h. Converter unlocked,in 3rd gear,icp had some oil in connector,unplugged it and ran pretty well, replaced sensor and saw no change in truck. Monitor pids and take recordings and all looks normal icp,ebp,map,all go up and down with surge.
Truck has a KN filter,pretty much no exhaust on it,customer has not had truck long and thinks its stock. It has unbelievable throttle response,like a 500hp muscle car with a stock converter,power seems normal other than the quick takeoff, I am thinking something else I cannot see has been done to the truck.
7.3's are not my thing,Much more used to 6.0 and 6.4
Any suggestions. Thanks Gord
Take a look at the back end of the PCM and see if it is chipped.... Oil in ICP wiring can do some funky stuff. Check to make sure the nut on the IPR is in place and snug. Assuming that there are no codes and the buzz test sounds good?
