2006 6.0- No Sync, Cam Slipped?
18 pulses left:
30 pulses left:
This is my known good, 14 pulses left:
New CMP, harness, no start, ICP between 900-2000 cranking.
It looks like the cam has slipped or is slipping. What would cause this?
:grin:
I'm assuming that the top two pics are the same engine but different instances?
With the way the cam gear is pressed on to the shaft, I'd be a little skeptical about the cam slipping (but I haven't seen everything there is to see - back in the 70's I came across a Ford 240 CID with a broken cam that would run well sometimes and not start others). It would be easier for me to imagine a damaged or loose crank trigger wheel as a possibility.
The spacing of the pulses suggests the engine is cranking over evenly without significant variation in rpm but the amplitude shows what could be an interesting trend.
  • 3 years later...
Hi Bruce & everyone
It looks to me (rookie)like there is a variance in the ckp trigger wheel =ing either speed or gap change (walking)
Hard to tell from a picture.
Did that ckp signal repeat like that in the image?
Was there a resolution to this one? Was the ckp trigger wheel hanging on by its last legs
Forgive me with so many questions
I know this post is old but was curious is all
Been reading a lot of you guys post and have been really enjoying them
This engine was removed and rebuilt by the customer. After installation, it did not start.
RPM pid kept jumping from 0 to 150 and there was no sync.
Somewhere during the process, the crank sensor trigger wheel teeth were hit and flattened/damaged. It was visible with a boroscope through the crank sensor hole, but hard to see and could be missed. It is very easy to see on the scope, the amplitude drops off.
