scott1984 Posted September 14, 2012 Share Posted September 14, 2012 ok guys check this out check this out got 06 f550 6.0 shut off going down the road. The driver cranked until batteries died. Got it in check fuel pressure 54 psi, ficm is at 48.5 while cranking,had ficm sync and pcm sync, icp at 115 with ipr shut off. Hey found my problem got a leak or bad ipr. air tested at icp no leak so I replaced ipr still nothing and this time only base pressure showing at icp. Hey got a bad pump replaced pump same thing tried 3 different ipr for s and gs. Hooked air directly in top of the pump closed ipr to check to see for leak there and and there was an oily fog the came out around oil cooler area. i figured i got a bad pump any help just a long week for me Quote Link to comment Share on other sites More sharing options...
Jeff Clyde Posted September 14, 2012 Share Posted September 14, 2012 Did you remove the plug from the pump prior to installing it ? Have seen this happen before. Quote Link to comment Share on other sites More sharing options...
ETS Posted September 14, 2012 Share Posted September 14, 2012 Got base oil prssure? Had one with severly damaged pump run me in circles. Found lifter rollers all the way to oil cooler. Quote Link to comment Share on other sites More sharing options...
joshbuys Posted September 14, 2012 Share Posted September 14, 2012 Did you remove the plug from the pump prior to installing it ? Have seen this happen before. +1 Been there done that! Quote Link to comment Share on other sites More sharing options...
scott1984 Posted September 14, 2012 Author Share Posted September 14, 2012 got base oil thinking i got a crack branch tube Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted September 15, 2012 Share Posted September 15, 2012 If it makes you feel any better, I have never seen a bad branch tube. Quote Link to comment Share on other sites More sharing options...
Jim Warman Posted September 15, 2012 Share Posted September 15, 2012 If it makes you feel any better, I have never seen a bad branch tube. Lucky prick.... Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted September 15, 2012 Share Posted September 15, 2012 And I have bent the shiiittt out of them things to get an STC fitting to line back up. Quote Link to comment Share on other sites More sharing options...
Aaron Posted September 16, 2012 Share Posted September 16, 2012 I had one that busted the rear cover it blew the fitting apart so bad and the branch tube was still ok. Quote Link to comment Share on other sites More sharing options...
cbriggs Posted September 26, 2012 Share Posted September 26, 2012 I've had several of those Aaron! Quote Link to comment Share on other sites More sharing options...
scott1984 Posted September 26, 2012 Author Share Posted September 26, 2012 ok guys check this out after a coulpe weeks working on this mug i found cracked branch tube, a small spilt in the pass. side standpipe, and a #8 injector top cracked. all three leaking oil. Before I foundthe injector leak I lost pcm sync and ficm sync. Found out that I had bad pcm. Customer came to pick up the truck I decided to run down the rode 1 last time. On the way back I lost boost. Found the egr valve wide open. and replaced it and then started smoking grayish color. Looked at my pids found ebp sensor at 50 cleared codes when down to 2. I replace the ebp sensor. Truck runs great. So yes this thang was turning my hair grey. Man what a story. Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted September 26, 2012 Share Posted September 26, 2012 6.0 Liters suck. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted September 26, 2012 Share Posted September 26, 2012 Quote Link to comment Share on other sites More sharing options...
ktmlew Posted September 27, 2012 Share Posted September 27, 2012 6.0 Liters suck. Nope...they blow! Quote Link to comment Share on other sites More sharing options...
