Aaron Posted October 5, 2012 Share Posted October 5, 2012 1FTWW31R08EA48264 My buddy just bought a motor and this VIN was on the valve cover. Was wondering the history on it, warranty or otherwise. Thanks a million fellows. Quote Link to comment Share on other sites More sharing options...
Alex Bruene Posted October 5, 2012 Share Posted October 5, 2012 OASIS RESULT: 1FTWW31R08EA48264 CAN: EN-US 05-OCTOBER-2012 / 13:05:26 EST/ APP2 Local Time: 5-OCTOBER-2012 / 1:05:28 PM VEHICLE INFORMATION VEHICLE DESCRIPTION: 2008 F-SERIES BODY STYLE: F-350 CREW CAB 4X4 ENGINE: 6.4L TC DIESEL V8 TRANSMISSION: TORQSHIFT AXLE CODE: 3L ENGINE CALIBRATION: 8F716A0A PAINT COLOR: VERMILION WB C/C-W/B PAINT CODE: F1 RADIO: PREM AM/FM STRO/CD CHANGER/CLK AXLE RATIO: 3.73 FINAL DRIVE RATIO WHEEL SIZE: 8 X 18" PREM CHROME STEEL WHL FRONT TIRE: LT 275/70R18E A/T OWL GROSS VEHICLE WEIGHT: 11,400 LB. GVW NO WARNING MESSAGES FOUND FOR THIS VIN GENERAL WARRANTY INFORMATION New Vehicle Base Warranty WARRANTY START DATE: 22-MAY-2008 BUILD DATE: 16-MARCH-2007 SALE MILEAGE: 00010 OUTSTANDING FIELD SERVICE ACTIONS NO CAMPAIGN MESSAGE(S) FOUND EXTENDED COVERAGES NO ESP INFORMATION AVAILABLE WARRANTY REPAIR HISTORY NO RECENT REPAIR HISTORY ON VEHICLE Click Here for Full Warranty History | Report a Vehicle Concern END OF OASIS REPORT FOR 1FTWW31R08EA48264 © Copyright 2002-2012 Ford Motor Company. All rights reserved. Quote Link to comment Share on other sites More sharing options...
Alex Bruene Posted October 5, 2012 Share Posted October 5, 2012 Detailed Vehicle Specification VIN 1FTWW31R08EA48264 Vehicle Line T/F7 Market Derived Code F Body Cab T/BC Ver. Series T/CD Drive Type T/E PLT CD A1 TRS CD T/BE ENG CD T/QL Production Date 16-MAR-07 Warranty Start Date 22-MAY-08 Selling Dealer 4B4074 Selling Country CAN AWS Claim Key Trx Code Time In Service Labor Hours Dealership DIST (Miles) Repair Date Prefix Base Suffix Doc Details 167429 1 0 .2 CELEBRATION FORD SALES LTD 32 01-OCT-07 * 14526 * 01216201 Customer Comments CHECK CAUSE OF HEATER FAN INOP C;VERIFY CONCERN, CHECK OASIS, INSPECT WIRING,OK,MEASURE VOL TAGE AT BLOWER MOTOR CONNECTOR, 0V, CHECK FUSES, FOUND THE 4 0 AMP FUSE IN PDB LOOSE, INSTALLED Tech Comments Details 262911 1 0 2.5 CELEBRATION FORD SALES LTD 415 21-NOV-07 * 3504 * 01271201 Customer Comments CHECK CAUSE OF OIL LEAK FROM POWER STEERING Tech Comments CHECKED CAUSE OF OIL LEAK FROM FRONT END INSPECTION REVEAL ED A LEAKING POWER STEERING GEAR. REMOVED GEAR. LEAK IS FR OM THE SECTOR SHAFT COVER. REMOVED THE COVER/SECTOR SHAFT TOGETHER FROM THE HOUSING. THERE IS A BURR ON THE HOUSING THAT GOUGED THE COVER AND DAMAGED THE O RING DURING ASSEMBLY ASSEMBLED THE GEARBOX. INSTALLED A NEW GEARBOX ON THE TRUCK TOPPED UP FLUID. TEST DROVE. RE CHECKE Details 655015 08C01 0 .3 CELEBRATION FORD SALES LTD 416 04-APR-08 * * * 01408301 Customer Comments RECALL 08C01 FRONT DRIVER SEAT BACK INSPECTION AND REPAIR Tech Comments INSPECT SEAT, NO CRACKS, INSTALLED CLAMP, ASSEMBLED SEAT Details 1622412 E84 4 2.7 CELEBRATION FORD SALES LTD 23269 17-SEP-08 8C3Z 8009 B 01570301 Customer Comments CHECK CAUSE OF COOLANT LEAK RIGHT FRONT CORNER Tech Comments CHECKED CAUSE OF A FREEZE LEAK. LEAK IS FROM TOP LH INS IDE OF THE RAD. REPLACED THE RAD AND INSTALLED THE VENTURI TEE AS PER SSM 20339. ADDED A FREEZE AND TEST DROVE. LEAK IS GONE. Details 2051199 E84 6 5.9 CELEBRATION FORD SALES LTD 30633 12-NOV-08 8C3Z 6700 A 01627801 Customer Comments CHECK CAUSE OF OIL LEAK UNDER VEHICLE Tech Comments FOUND OIL AROUND FRONT CRANK SEAL/FRONT OIL PAN. CLEAN, RUN ENGINE, INSPECT WITH UV LIGHT, FOUND LEAK FROM CRANK SEAL. REMOVE UPPER SHROUD,CAC TUBES, FAN SHIELD, FAN, HARMON BALANCER. INSTALL SEAL AND REINSTALL ALL PARTS. CHECK FOR LEAKS OK. SET OIL LEVEL AND CLEAN OFF ANY RESIDUAL OIL. Details 2606616 08B03 9 .9 CELEBRATION FORD SALES LTD 37346 21-JAN-09 * * * 01706602 Customer Comments PERFORM RECALL 08B03 FUEL TANK STOP Tech Comments INSTALLED FUEL TANK STOPPER BRACKET Details 2606615 08B07 9 .5 CELEBRATION FORD SALES LTD 37346 21-JAN-09 * * * 01706601 Customer Comments PERFORM RECALL 08B07 REFLASH PCM Tech Comments PERFORM RECALL 08B07 (REFLASH THE PCM, TCM AND IC) Details 3124101 S07 11 1.8 HANSEN FORD INC. 43520 19-MAR-09 8C3Z 12B591 B 014226A Customer Comments CHECK AND ADVISE ON CEL LIGHT Tech Comments 70040 VERIFIED CEL LIGHT. DID VISUAL OK. OIL AND FUEKL OK. DID KOEO PULLED CODE P040D CONT. P040D DID PIN POINT TEST NEEDS EGRT SENSOR RE AND RE RIGHT INNER FENDER REPALCED EGRT CLEARED CODE ROAD TEST OK DID KOEO PASS NO POWER BECAUSE UNIT WAS IN LIMP MODE OK NOW SLTS TIME TO REPLACE THE SENSOR DOES NOT INDICATE THAT IT INCLUDES THE TIME TO REMOVE THE WHEEL Details 3467818 S07 11 2.7 CELEBRATION FORD SALES LTD 45166 06-APR-09 8C3Z 9F479 A 01781401 Customer Comments CHECK CAUSE OF ENGINE LIGHT ON Tech Comments SELF TST,P222,EXAMIN F.F. DATA,CODE @ IDLE,MAO 11.3PSI,BAR O 13.9 PSI,MONITOR PIDS@IDLE MAP 16,BARO 13.9,INSPECT INTAKE ,INSPECT EXHAUST FOR LEAKES,RESTRICT,IONS,OK PINPOINT,INSPEC T TURBO,CHECK RETURNABILITY OF ACTUATOCRITICAL OP,OK,TURBO O K EGR SYSTEM OK,BACK PRESSUR OK,INSPECT MAP CONNECTOR/WIRING ,TEST WIRES OK,REPLACE MAP SENSOR,CLEAR CODE, RT,OK MT6K682 CHECKING TURBO LINKAGE AND ACTUATOR Details 3549730 E95 12 2.2 CELEBRATION FORD SALES LTD 47984 01-MAY-09 8C3Z 9G282 A 01811601 Customer Comments CHECK CAUSE OF INTERMITTENT WRENCH LIGHT ON Tech Comments SELF TEST,P0087, P0232, CHECK OASIS,P0087 WAS LIKLY CAUSED BY P0232, GO TO PINPOINT MA, P0232 IS A HARD FAULT, CHECKED THE WIRING FROM THE PCM TO FUEL PUMP FOR OPENS AND SHORTS, OK, MEASURED FUEL PUMP RESISTANCE, IT IS GREATER THAN 5 OHMS , REPLACED THE FUEL PUMP, CLEAR CODES, RT, SELF TEST, PASS, OK Details 6012678 E95 24 3.5 CELEBRATION FORD SALES LTD 78505 05-MAY-10 F81Z 1244 AB 02226801 Customer Comments CHECK CAUSE OF LOOSE REAR END MOVEMENT IN TIRES. Tech Comments RAISE REAR OF TRUCK, CHECK FOR MOVEMENT IN REAR WHEEL BEARINGS. IT DOES HAVE EXCESSVICE PLAY, DISSASSEMBLE AND REMOVED HUBS. CLEANED AND INSPECTED THE BEARINGS AND RACES. FOUND WEAR ON SURFACES, CAUSING THE PLAY. REPLACED THE BEARINGS AND RACES ON BOTH SIDES. ASSEMBLED AND SET BEARING PRELOAD. TOP UP FLUID, RT, INSPECT OK. *MT TIME IS FOR IN Details 6035026 E72 25 1.6 CELEBRATION FORD SALES LTD 79611 04-JUN-10 7C3Z 6B209 D 02262801 Customer Comments CHECK CAUSE OF NOISE UNDER HOOD Tech Comments VERIFY NOISE, CAN HEAR THE FEAD BELT SQUEAKING, INSPECT FE AD COMPONENTS, FOUND THE TENSIONER MISSALIGNED AND DAMAGED, MAIN BELT OK, A/C BELT IS BROKEN, ITS TENSIONER IS OK, REPLA CED MAIN TENSIONER AND A/C BELT, VERIFY REPAIR, OK Details 6358379 E72 27 2.2 CAPITAL FORD LINCOLN INC 91771 09-AUG-10 7C3Z 6B209 B 37939802 Customer Comments A/C BELT CAME OFF (E20) Tech Comments INSPECT BELTS FOUND A/C TENSIONER FAILED, BELT DAMAGED REPLACE TENSIONER AND BELT AND ROADTEST OK(01) Details 6393815 S07 27 1.9 CAPITAL FORD LINCOLN INC 91771 09-AUG-10 8C3Z 9D475 D 37939801 Customer Comments BOGS DOWN LACK OF POWER ON ACCELL (D42) Tech Comments CARRY OUT PERFORMANCE DIAGNOSIS RETREIVE CODE P042F,PINPOINT TEST FOUND EGR VALVE STUCK CLOSED, ATTEMPT TO REMOVE EGRVALVE SEIZED IN HOUSING PARTIALLY. REMOVE EGR COOLER FOR ACCESS REPLACE EGR VALVE AND HOUSING. RETEST SYSTEM AND ROAD TEST. OK. (42) OSP WAS USED FOR AIR FILTER CLEANER, AND TECHNICIAN ATTEMPTED TO REMOVED CLOSED EGR VALVE BUT IT Quote Link to comment Share on other sites More sharing options...
Aaron Posted October 6, 2012 Author Share Posted October 6, 2012 Thanks dude! Quote Link to comment Share on other sites More sharing options...
