ktmlew Posted October 9, 2012 Share Posted October 9, 2012 A truck came in today that another tech changed oil in a couple weeks ago. The truck had a coolant leak or at least was "missing" coolant at previous visit. Customer refused any repair or diag at the time. Now it's blowing coolant out tailpipe. Other tech started to pressure test cooling system. I told him he was wasting his time. Suggested he remove EGR valve and lift rear of truck which we did. Of course intake was full of coolant, which is actually 95% water as customer had been adding 10-12 gals of water a day. Truck got handed off to me. I removed the NAPA oil filter to find top of standpipe missing. Oh! There it is...stuck in filter. Bottom of filter is starting to melt. Upper part of standpipe that has bypass valve is stuck in filter and when removed show signs of starting to melt. I tell shop owner we probably should punt as engine is likely toast. She has a head made of cast-iron...nothing penetrates. She only sees potential dollars...I see a truck that is a grenade with a loose pin. After more than an hour of her badgering, I finally tell her the next best step is a compression test. Since we have only a Modis & my AutoEnginuity, a manual test it is. I haven't figured out a way to reliably remove the GP harness w/o damage so I give her (shop owner) the prices for GP harnesses and 3hrs labor to start with. Figure whole job <EGR & Oil Cooler/coolant flush/oil change/fluids/etc>is going to be around $3500.00, if it passes compression test. Customer balks at "potential repair" price. I had mentioned concerns about NAPA oil filter and possible shop exposure to lawsuit if customer was so inclined if truck fails in near future. I still felt it probably best to send him to the dealer. She could not grasp that an aftermarket filter could be different than original so I ordered Ford parts. The NAPA part we installed is actually correct length and seems to be a "reasonable" fit. Now shop owner STILL doesn't believe oil filter could have any bearing on coolant running out of tailpipe and/or hyrolocking engine...all she knows is $$$$ she wants. Customer declines any repair...shop owner refuses to allow that...sells customer oil change so she doesn't have to pay 20% restocking fee to return Ford oil filter & cap. I try to explain that changing oil is wasting time/money/oil which goes in-one-ear-out-other...I drain oil. At least a gallon of coolant comes out first. Just as I am finishing oil change shop owner comes out and says customer now wants us to "fix" the vehicle so it will run. She wants me to put coolant in it so he can drive it. Jebus Christmas lady...how many ways do I have to explain this to you? Customer calls back again a few minutes later, says wants to do complete repair IF it passes compression test. I checked codes before starting to remove GP harness. Will list tomorrow as there were too many to remember. I do remember all cyls had inj low codes, a couple cyls (2&4) contribution, one GP (4), PO611 & 674 going from memory. The regular Manager was off since last Thursday. Went racing. The owner is a complete idiot. No clue about anything. Next time he takes off I'm afraid I'll commit homicide... Quote Link to comment Share on other sites More sharing options...
ktmlew Posted October 9, 2012 Author Share Posted October 9, 2012 OK. PO611 is likely FICM half-shell and PO674 was the cyl 4 GP code. I dread trying to fix this truck. This is gonna turn ugly. Quote Link to comment Share on other sites More sharing options...
ktmlew Posted October 9, 2012 Author Share Posted October 9, 2012 Just noticed my last post was #10000 for thsi section. Do I get a prize? Quote Link to comment Share on other sites More sharing options...
Jim Warman Posted October 9, 2012 Share Posted October 9, 2012 Just noticed my last post was #10000 for thsi section. Do I get a prize? Yes... you get to work on a 2006 6.0 that barfs coolant all over the road. Lucky you..... Quote Link to comment Share on other sites More sharing options...
cbriggs Posted October 9, 2012 Share Posted October 9, 2012 If this is a high mileage truck, say around 200k (120,000 miles)or higher, and that much water has gone thru it, you may be replacing all the injectors, either before it leaves or very,very shortly after. The P0611 and the low injector circuit codes are all signs of a bad transformer in the ficm. Quote Link to comment Share on other sites More sharing options...
ktmlew Posted October 9, 2012 Author Share Posted October 9, 2012 Worst hole 290 best @ 320. Fix'er up boyeee... Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted October 10, 2012 Share Posted October 10, 2012 you wouldn't believe how many people try to agrue with me the fact that a failed egr cooler will put coolant in the oil. Is it that hard of a concept to grasp? Quote Link to comment Share on other sites More sharing options...
ETS Posted October 18, 2012 Share Posted October 18, 2012 Sounds like BIG fun. That is exactly why I left my last dealership job. Woman was a cook before she joined GM dealership as circus manager. Had no clue and got an attitude when you tried to explain something technical to her. Told owner it was her or me. I left and a month later he was on the phone trying to rehire me. I had one last year, NAPA filter TOP, Ford filter, NO BASE OIL PRESSURE. NAPA top is slightly taller. Caused oil to bypass ack to pan. It was towed in, No start from local sand & gravel company. Tore top and front off motor tracing flow and pressure testing before I saw NAPA part# stamped in ink on top and compared parts side by side. One for the memory bank. Quote Link to comment Share on other sites More sharing options...
ktmlew Posted October 18, 2012 Author Share Posted October 18, 2012 Believe it or not but still not finished. They won't let you concentrate on one vehicle. I did get to start it right before I left this evening though. No coolant in it yet. Trying to decide if I'm going to do any flushing. I did drain the block plugs today. Coolant looked clean. Guess it should as customer said he put 15 gallons of anti-freeze (green) in it last week it ran. Customer was really surprised that using coolant at that rate could cause damage. I did convince him to let me replace the STC fitting. Truck has 160K miles but costomer has put 60K of that on it w/o any repairs. It had the steel bracket on it so had been replaced at some point. I suggested we have the latest flash done so it won't "hurt" itself in the future. If he's gonna be stupid, better have the "stupid" flash done, right? I doubt this vehicle has been flashed in the last 2 or so years so some updates are quite due. Quote Link to comment Share on other sites More sharing options...
Mbl35 Posted October 18, 2012 Share Posted October 18, 2012 Id explain to your lovely boss to be aware that the truck may come back for a crank no start or it may happen before the truck leaves tje shop after coolers replacement. All the coolant sludgees up on the injector tips. You will have very little precycle or none at all, problobly no related codes and ficm sync/sync will both read yes. =All 8 injector time. It has happened to me a few times. Have fun Quote Link to comment Share on other sites More sharing options...
ktmlew Posted October 18, 2012 Author Share Posted October 18, 2012 Long crank time. No oil pressure until after it fires up. Removed oil filter and oil is flowing immediately. I'm wondering if the drain ck-valve is partly melted/fouled and the filter is draining? I have NOT driven the truck yet but it has been run for about 1/2 hr. Had several coolant leaks at the damn spring clamps...did dump a couple bottles of flush in and am running it on water. Going to Lowes to get a guage and some fittings to tee into de-gas bottle. Has significant blow-by... Quote Link to comment Share on other sites More sharing options...
ktmlew Posted October 19, 2012 Author Share Posted October 19, 2012 Test drove with water in cooling system. All systems GO! Now draining water. Still kicking all inj low & 611 code. Ficm power around 41v when warm. Will discuss next step with customer tomorrow. Quote Link to comment Share on other sites More sharing options...
ktmlew Posted October 19, 2012 Author Share Posted October 19, 2012 Truck fired right up this morning. Just drained water & added coolant. Manager doesn't want to sell him the FICM so no re-flash at this point. To make this even better they are trying to screw me out of my commission on this job. Trying to break the ticket up so i don't hit my number...she "paid" $600.00 of it on last week. The week i didn't beat my guarantee, So she just cut about $90.00 off my next check... Quote Link to comment Share on other sites More sharing options...
ktmlew Posted October 20, 2012 Author Share Posted October 20, 2012 Truck is done and so am I. We agreed that "we" weren't a good fit. Another one bites the dust. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted October 20, 2012 Share Posted October 20, 2012 ouch, sorry to hear that Quote Link to comment Share on other sites More sharing options...
