oh boy
Got a 98 mid year bulid f550 have replaced engine due to lost of compression on number 5. Now its setting high side to low side open for every injector. And my shop info is down for maintenance so any help would be great
Make sure that big connector at the driver side valve cover doesn't have a bent bracket causing the harness to lay on the valve cover and rub through. I have seen that happen many times were the wire rubbed trought to the copper in that harness and it will arc through to the valve cover giving you that code if the right circuit is rubbing on that cover. Happened on my own truck and every time I washed the engine it would miss because the water would conduct from the harness to the cover.
No i am getting each code for all eight injectors. Brad hope ur enjoying nc it is a remand. I replaced the gasket and harness on engine assembly. It was bent but like all i straighten it.
yeah man it is kinda nice right now the place i work at is in plymouth about an 40 mins east of greenvile i pm u our address. And yes idm was bad but they joy of putting head gaskets on a idi 7.3l.
