3.2L Power Stroke Engine
New to us this is an 3.2L in-line 5 cylinder engine that is now officially going to be in the 2014 Ford Transit in North America. Oh boy! Another engine to learn.
Ford's Press Release
Advanced, Fuel-Efficient 3.2-Liter Power Stroke Turbo Diesel Makes North American Debut in All-New 2014 Ford Transit
-Already a proven global workhorse, Ford adds 3.2-liter five-cylinder turbo diesel to fuel-efficient North American lineup in all-new Transit commercial van range
-This innovative engine features state-of-the-art fuel, turbo and emissions systems that meet stringent U.S. clean diesel standards
-The 3.2-liter Power Stroke® Diesel will deliver outstanding performance, exceptional fuel economy and low operating costs
DEARBORN, Mich., Dec. 10, 2012 – Ford's all-new Transit full-size van, which goes on sale late next year, will be offered with a new clean-running 3.2-liter Power Stroke® five-cylinder diesel, further bolstering Ford's lineup of fuel-efficient cars, trucks and SUVs.
The new diesel, Ford's second in North America, already has established a proven record for reliability, durability and refinement in the global Ford Ranger truck sold in world markets. The new Power Stroke Diesel will be the only five-cylinder diesel engine available in a commercial van in North America.
"Commercial van drivers spend most of their working hours behind the wheel. We know they want a fuel-efficient diesel engine with smooth, responsive performance and low operating costs," said Joe Bakaj, Ford vice president of Powertrain Engineering. "The 3.2-liter Power Stroke engine has been developed and proven globally to deliver a world-class combination of power, fuel economy and refinement."
The 3.2-liter will join the most fuel-efficient lineup in Ford Motor Company's history. Next year, Ford will offer eight vehicles rated at 40 mpg or higher – double today's total, and more than any other automaker. Ford tops Toyota in fuel economy in every segment in which both companies compete.
While power has not been certified for North America, the new diesel engine is rated in Europe at 197 horsepower and 347 lb.-ft. of torque.
Like the larger 6.7-liter Power Stroke V8 offered in Ford F-Series Super Duty trucks, the fuel system has been carefully tailored and calibrated for combustion efficiency. It enables the newest Power Stroke to achieve exceptional fuel economy ratings without affecting power levels.
The 3.2-liter turbo diesel features state-of-the-art piezoelectric fuel injectors fed through a high-pressure common rail fuel system, and advanced emissions technologies.
Precise injection timing and calibration also ensures a smooth combustion process to reduce hard diesel combustion clatter, resulting in lower noise levels that are more like a gasoline engine. Each injector nozzle has eight spray holes and can deliver up to five injections per combustion cycle. A pilot injection controls noise levels and a main injection is used for power generation.
Technical features of the new Power Stroke 3.2-liter include:
-Quick-start glow plugs that enable smooth and fast startups at temperatures down to 25 degrees F
-Durable, rigid sand-cast gray iron cylinder block
-Aluminum cylinder heads with double overhead cams and four valves per cylinder
-Advanced common rail piezoelectric fuel injectors that deliver multiple injections per stroke to improve performance and reduce NVH; maximum fuel pressure is 26,100 psi
-Variable nozzle turbocharger with electronic actuation; maximum impellor speed of 197,800 rpm
-First application of selective catalytic reduction for reduced nitrogen oxide emissions in a Ford van
-Integrated diesel oxidation catalyst and diesel particulate filter to save space
-Expected to be B20 biodiesel compatible
Additionally, the engine features cast-aluminum, low-friction coated pistons with piston-cooling jets, which squirt oil on the underside of the pistons to keep the piston crowns cool under extreme operating conditions. Also included is a water-cooled high-performance electric-controlled exhaust gas recirculation valve that is better able to withstand coolant pressure drops.
The 3.2-liter Power Stroke is one of several engines that will be available for Transit in North America, including the proven 3.5-liter EcoBoost®gasoline engine. All engines are mated to a Ford 6R80 six-speed automatic transmission.
With a flat torque plateau – 90 percent of its peak torque is available from 1,700 to 3,500 rpm, providing better engine flexibility – Transit will be able to effortlessly haul full loads in town and on the highway, while offering flexible performance across each gear in the six-speed automatic transmission.
"The Power Stroke name is synonymous with power, work and long-term durability," said Bakaj. "We're confident our commercial van customers will be extremely pleased with the 3.2-liter's fuel economy, performance and running costs."
The Power Stroke 3.2-liter is manufactured in Ford's Struandale Engine Plant in Port Elizabeth, South Africa. It will be exported to Ford's Kansas City Assembly Plant in Claycomo, Mo., which received a $1.1 billion investment for the Transit.
About Ford Motor Company
Ford Motor Company, a global automotive industry leader based in Dearborn, Mich., manufactures or distributes automobiles across six continents. With about 172,000 employees and 65 plants worldwide, the company's automotive brands include Ford and Lincoln. The company provides financial services through Ford Motor Credit Company. For more information regarding Ford and its products worldwide, please visit http://corporate.ford.com.
I noticed the front engine mount bracket and no room for side engine mounts. Wonder what tranny goes behind it in order to accommodate the missing side engine mounts?
You should able to go into PTS and pick 2012 Transit as the vehicle to get an idea of what your getting into. Obviously it isnt the exact same but the general idea is there.
They show no front engine mounting in there, so there must be room for side engine mounts. Honestly doesn't look hard to work on. Just getting to it is the big mystery.
I guess it is made in Africa
Is this the same as using 6v glow plugs like on the six nine? Cos those never went bad ...
You think this is used sideways in the FWD units in other markets and doesn't show the side mounts for longitudinal mount in a RWD platform?
I always get a chuckle out of the press release stuff that uses things like "Variable nozzle turbocharger with electronic actuation; maximum impellor speed of 197,800 rpm". I know the speed will never ever go to 197,801 RPM which would make the turbo explode.
I question if the engine in the picture in this post is the ACTUAL engine going in our Transit van here in America They are also calling it a Powerstroke not a Duratorq which sounds too much like a duramax anyway
And other articles about this state it as being based on the popular European engine. Most likely it has a few tweaks for our market, like 12V glow plugs.
  • 1 month later...
Just an added tid-bit, the picture info has a date/time stamp from 2006! (2006:02:15 23:46:20) So the picture we have all been fed is about 7 years old. It probably does not matter much but you would think Ford would publish a current photo of the engine wouldn't ya?
  • 3 months later...
  • 7 months later...
You guys might have seen it already but the Transit order guide hit FMCDealer the other day.  It has power ratings but not fuel economy. No mention of the diesel being late availability which surprises me.  The '15 Super Duty guide is up too.
  • 4 months later...
I got my manager to put in a request today for the transit new model training classroom.  I told him only way to get any training on new diesel engine. I dont think there was any chance I could go to a new model training otherwise.
I have a buddy at the next dealer over and he also convinced his boss he needs the class. An email to the teacher at the twin cities training center and we will be in class together. That is when he is able to schedule it they havent gotten him a van or material yet. Its nice to go with someone to class its about a two hour drive to training center.
Silly question:  I was looking at the WSM for both the US version of the 3.2 vs the Euro version.
Why would they eliminate the centrifugal oil filter in the valve cover that the Euro version uses, or did I just miss it?
With that tiny looking main oil filter, what's the US change interval?
From watching some GB auto shows and other Euro stuff, the 3.2 is very popular.  Especially in the new Ranger and Everest we don't get.  WHY?  I think it would sell like crazy here.
