batmantech Posted December 12, 2012 Share Posted December 12, 2012 Seems like this dipstick design is not "robust" enough. Seeing many different trucks with these tubes either broke next to the holding bracket or a spot weld breaks at the holder. Resulting in these oil leaks. Anyone else seeing these regularly? Any repeat breaks after 20-30,000 miles. I am thinking about modifing the bracket. Cutting off the bracket wrapping in rubber hose to isolate it then secure to stud and prevent crack or break in the future. Quote Link to comment Share on other sites More sharing options...
amailloux Posted December 12, 2012 Share Posted December 12, 2012 I have seen a handfull, and have had no repeat failure. Just put an engine in 1 I replaced the tube on 20k ago. I think they are flexed during service, and finally fatigue enough to break. Those things make a huge mess under the truck. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted December 13, 2012 Share Posted December 13, 2012 No repeat leaks but I'll frequently change them just for the hell of it on customer pay jobs. I've had many break at the bracket and a few rub through on the horizontal cooler Quote Link to comment Share on other sites More sharing options...
Aaron Posted December 22, 2012 Share Posted December 22, 2012 Seen a few broken at the spot welds. Truck came to me from another dealer after getting glow plug harness, three valve cover gaskets and then a cover replaced for porosity, to fix that oil leak. Quote Link to comment Share on other sites More sharing options...
lmorris Posted January 8, 2013 Share Posted January 8, 2013 All the broken ones we have seen were tight to the EGR cooler and vibrating nastily at idle. Quote Link to comment Share on other sites More sharing options...
