Matt Saunoras Posted December 18, 2012 Share Posted December 18, 2012 Is there any chance this stud is availbale seperately? It's 2 different thread sizes on each end and the hydroboost end is reverse threaded. This one was from a 05 F-550 6.0L. ....and no i didn't break it. It came in for a soft brake pedal Quote Link to comment Share on other sites More sharing options...
amailloux Posted December 18, 2012 Share Posted December 18, 2012 I stock a set I kept out of a GM booster if you can't find it I will send both to you. Quote Link to comment Share on other sites More sharing options...
Fordracer Posted December 19, 2012 Share Posted December 19, 2012 It shows you can get the nut but not the bolt. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted January 1, 2013 Author Share Posted January 1, 2013 I let the truck go with some M10 10.9 grade flange bolts and locking nuts in place of the studs. The customer opted for this instead of hydroboost replacement. Surprisingly the bolts centered up very well in the reverse threaded M12 holes. I don't believe master to booster alignment will be an issue. I see the truck regularly (it's even spent the night at my house before) so I'll be able to keep an eye on it. Quote Link to comment Share on other sites More sharing options...
