mchan68 Posted May 30, 2013 Share Posted May 30, 2013 Alex_Bruene said: I've never done a 6.4 long block... Only complete drop ins or ESBs... What does the long block come with?Okay, perhaps I should've clarified it was a drop-in assembly including turbos and basically everything else except the engine harness. After buttoning it up with a new rocker arm and repeating several manual compression tests followed by a relative compression test with satisfactory results, I completely re-assembled it and fired it up. After running it for a bit, I went on a very brief road test around the block without issue. In the middle of doing a manual regen, the truck just shut off by itself. When I tried to restart it, FRP wouldn't go any higher than 237 psi. Quote Link to comment Share on other sites More sharing options...
