2013 Truck & Diesel SSMs
Keith Browning
Dec 23 2013 4470 -2011-2013 F650/F750 with Diesel Engine, Diesel Exhaust Fluid (DEF) Level Gauge Improper Level Indication
An improperly filled DEF tank can result in erroneous DEF gauge indication if the DEF tank is filled past the recommended fill level. When this occurs the gauge may read in reverse indicating a low level of DEF fluid. Prior to performing any diagnostics or service, the DEF fluid level should be verified that the fluid level does not exceed the recommended fill level. Using a fuel type nozzle system with an automatic shutoff or containers that utilize a spout with a seal and an internal vent such as Motorcraft DEF or equivalent will prevent overfilling. It may be necessary to drain the DEF tank following the procedure in Workshop Manual 308-08 and refilling it to verify the proper level. It is important that the operator follow the DEF tank fill procedure in the Owner Guide.
Dec 23 2013 4469 -2013 F650/750 - Poor Outbound Call Quality While Using Sync Built On Or Before 6/5/2013
Ford engineering is aware of a concern on 2013 F650/750 Sync equipped trucks produced on or before 6-5-2013 that may exhibit poor outbound call quality when using Sync. A permanent repair is being developed and will be released in the first quarter of 2014. Please do not attempt a repair at this time.
Dec 13 2013 4439 -Some 2013 F650/750 Vehicles Built From 7/29/2013 Through 10/28/2013 Equipped With Diesel Engine May Have An Inoperative Fuel Transfer Pump
Some 2013 F650/750 Diesel equipped vehicles built from 7/29/2013 through 10/28/2013 may have an inoperative fuel transfer pump. This may be due to connector C102C/circuit 1818 WH/BK not being connected. If encountered, check that connector C102C/circuit 1818 WH/BK is connected to the generator W terminal as shown in the online wiring diagram. The circuit may be taped back to the vehicle harness. Torque the connection nut to 3 Nm (14 lb in) on 185 amp generators and 5 Nm (44 lb in) on 220/320 amp generators. Refer to the online wiring diagram for locations.
Dec 11 2013 4426 -2013-2014 F-Super Duty - 6.7L Diesel - Diagnostic Trouble Codes (DTC) P2201, P2209, P229E, P22A7, P220F - NOx Sensor And Module Replacement
Some 2013-2014 F-Super Duty vehicles equipped with a 6.7L Diesel engine may exhibit the Malfunction Indicator Light (MIL) on with DTC(s) P2201, P2209, P229E, P22A7, P220F. Engineering is currently reviewing NOx sensors and modules for root cause analysis. If diagnostics lead to the replacement of a NOx sensor, replace the corresponding NOx module as a matched set. If diagnostics lead to the replacement of a NOx module, replace the corresponding NOx sensor as a matched set. During replacement, be sure to leave the NOx module/sensor interface connector undisturbed and connected as this will aid in concern analysis. NOTE: 2013 and later 6.7L diesels have two NOx sensors and two NOx modules. The upstream NOx sensor/module is NOx_11 and the downstream NOx sensor/module is NOx_12.
Dec 10 2013 4418 -2013 C-Max and F-Super Duty equipped with MyFord Touch Radio Lock Up/Inoperable
Some 2013 C-Max and F-Super Duty vehicles equipped with MyFord Touch may exhibit a concern where the radio will not turn on, message saying SIRUS Update stuck at 0% status, CD will not eject with message saying - No Disk. To temporarily correct this condition, remove fuse 29 from the Body Control Module (BCM) on F-Super Duty and both fuse 67 and 79 on the C-Max for a minimum of 30 seconds to reset the Audio Control Module (ACM). A permanent software fix is being developed, continue to monitor oasis for updates.
Nov 20 2013 4346 -2003-2014 TorqShift (5R110W) Equipped Vehicles May Exhibit Symptoms Of Water Contamination In The Automatic Transmission Fluid (ATF).
Some 2003-2014 TorqShift (5R110W) equipped vehicles may exhibit symptoms of water contamination in the automatic transmission fluid (ATF). Symptoms include shift or engagement concerns, overfilled ATF or ATF that may be foamy or pink in color. If evidence of water contamination is found, inspect all dipstick tube sections to verify they are completely seated. Please also inspect the dipstick tube to case joint, or the upper dipstick to lower dipstick tube O-ring for damage and proper installation prior to repairing the transmission. If water is found in the transmission, please refer to workshop manual section 307-01, under Diagnosis and Testing and Preliminary Inspection for the correct repair procedure.
Nov 13 2013 4328 -2013-2014 F-Super Duty 6.7L Diesel - Malfunction Indicator Light (MIL) On With DTC P246F, P246E, P242A, P22FF, P2080, P2084, P242B, P2470, P2031, P0544 - EGT Sensor Replacement
Some 2013-2014 F-Super Duty vehicles equipped with a 6.7L Diesel engine may exhibit DTCs P246F, P246E, P242A, P22FF, P2080, P2084, P242B, P2470, P2031, P0544. When diagnosing any of these DTCs, if normal PC/ED diagnostics lead to replacement of an EGT sensor, replace the sensor and the corresponding connector on the wire harness using pigtail kit (3U2Z-14S411-BXAB). During sensor/connector replacement do not disconnect the sensor from the main harness. Replace the sensor and connector as an assembly.
Nov 06 2013 4293 -2011-2014 - F-Super Duty - 6.7L Diesel - Operator Commanded Regeneration (OCR) Capability For Vehicles With Standard Level Instrument Cluster Only
See TSB: 13-11-14 for details.
Nov 04 2013 4273 -6.7L - MIL On - DTCs P207F, P20EE, P2200, P2201, P2209, P164A, P2A00 And/Or P0133 - Built On Or Before 10/11/2011
See TSB: 13-11-06 for details.
Oct 11 2013 4175 -2013 - F-Super Duty - 6.7L Diesel - Malfunction Indicator Light (MIL) On - DTCs P2002, P208E, P06EA, P06EB - Exhaust Fluid System Fault - Forced Idle
See TSB: 13-10-11 for details.
Oct 10 2013 4166 -2011-2012 F-Super Duty 6.8L Engine - Stationary Elevated Idle Control (SEIC) With Power Take-Off (PTO) - Built On Or Before 12/16/2011
See TSB: 13-10-09 for details.
2011-2014 F-Super Duty - 6.7L Diesel - Hard Start/No Start/Rough Run/Lack Of Power/Malfunction Indicator Light- Fuel Gelling In Colder Ambient Temperatures
Some 2011-2014 F-Super Duty vehicles equipped with a 6.7L diesel engine may exhibit hard starting, lack of power and/or a running rough condition with a MIL and Diagnostic Trouble Codes (DTC) P008A, P2291 and/or P0087 due to fuel gelling in cold ambient temperatures. Please note that bio-diesel blend fuels have a higher occurrence of fuel gelling and should not be used at any rating above B20 (20%). If no root cause is determined after normal PC/ED diagnostics, recommend that the customer use a different fuel that has been seasonally adjusted for the ambient temperature. Customers may also benefit from using Motorcraft PM-23-A (US), PM-23B (Canada) diesel fuel anti-gel and performance improver. Refer to the vehicles owner guide diesel supplement for additional details.
Sep 25 2013 4101 -2011-2014 F-Super Duty Equipped With Air Conditioning - Dirt Or Dust Coming Out Of Vents
Some 2011-2014 F-Super Duty vehicles equipped with air conditioning and operated in extremely dusty environments and/or extended idle time may exhibit dirt/dust coming out of the instrument panel vents. Advise operator to put the Heating, Ventilating Air Conditioning (HVAC) controls in the recirculated air mode when operating under these conditions, this helps prevent the ingestion of dust/dirt through the cowl and into the HVAC system. Note: If a functional condition does exist, proceed with normal diagnostics in workshop manual section 412-00.
Sep 25 2013 4100 -2009 -2013 F650/750 Vehicles with Hydraulic Brakes – Invalid DTC (diagnostic trouble code) set in the GEM (Generic Electronic Module).
During diagnostics a C1268 (Hydromax Motor Relay # 1 Circuit Failure) DTC may be encountered from the GEM when pulling codes or after configuring a new GEM. Because Hydromax is no longer used this DTC should be ignored. There is currently no method to configure the GEM to not set this DTC.
Sep 24 2013 4097 -2011-2014 F-SUPER DUTY - UNDER HOOD ENGINE SHIELD (BASE 16A238) - DIFFERENCES BETWEEN 6.7L DIESEL AND 6.8L/6.2L GAS ENGINE APPLICATION(S)
2011-2014 F-Super Duty may exhibit a customer complaint that one of the under hood air deflector shield (16A238) is missing on the hood. The 6.7L diesel application requires only one shield, BC3Z-16A238-A to be installed on the underside of the hood on the passenger side. The 6.2L and 6.8L gas application requires only one shield, BC3Z-16A238-C to be installed on the underside of the hood on the driver side. No vehicle was design with both shields and may have an adverse effect on vehicle performance if added. Follow normal Ford catalog advantage or DOES II Part(S) systems for correct part application and availability.
Sep 24 2013 4095 -2013-2014 F-250/F-350 - Sticking/Binding Front or Rear Brake Calipers
If a sticking/binding front or rear brake caliper is diagnosed on a 2013 or 2014 F-250/F-350, replace the complete caliper assembly (including the caliper bracket, brake pads and clips) by unbolting the caliper bracket assy from the front knuckle/spindle assembly or rear caliper support. Don't remove the brake pads from the caliper bracket assembly. Use service labor times standard (SLTS) operations. Engineering is investigating and needs the parts back as an assembly. Please continue to monitor OASIS and submit GCR Reports.
Sep 16 2013 6611 -2011-2013 F-Super Duty Pickup Truck - 6.7L Diesel Engine - Runs Rough/Misfire During Exhaust Regeneration Process
See TSB: 13-09-15 for details.
Sep 16 2013 6610 -2011-2014 - F-Super Duty - 6.7L Diesel - Malfunction Indicator Lamp (MIL) And Diagnostic Trouble Code (DTC) P2043
See TSB: 13-09-14 for details.
Sep 19 2013 4065 -Some 2011-2014 F-Super Duty Vehicles May Exhibit An Optical Illusion Of The Rear Suspension Dog Tracking Or Axle Not Square To The Frame
Some 2011-2014 F-Super Duty 4x4 vehicles may exhibit a customer complaint that their F-Super Duty appears to dog-track. The front axle track width is wider than the rear axle track width. This difference in track width can cause an optical illusion that gives the impression that the vehicle is dog-tracking. If the vehicle is dog-tracking and it is not an optical illusion caused by the track width difference, refer to workshop manual section 204-00 for updated diagnostics and repair.
Sep 12 2013 6595 -2013-2014 F-Super Duty - 6.7L Diesel - MIL On With DTC P246F, P246E, P242A, P22FF, P2080, P2084, P242B, P2470, P2031, P0544 - EGT Sensor Replacement
Some 2013 F-Super Duty vehicles equipped with a 6.7L Diesel engine may exhibit DTCs P246F, P246E, P242A, P22FF, P2080, P2084, P242B, P2470, P2031, P0544. When diagnosing any of these DTCs, if normal PC/ED diagnostics lead to replacement of an EGT sensor, replace the sensor and the corresponding connector on the wire harness using pigtail kit (3U2Z-14S411-BXAB).
Sep 12 2013 6594 -2011-2012 F650/F750 with Diesel Engine, Diesel Exhaust Fluid (DEF) Level Gauge Improper Level Indication
An improperly filled DEF tank can result in erroneous DEF gauge indication if the DEF tank is filled past the recommended fill level. When this occurs the gauge may read in reverse indicating a low level of DEF fluid. Prior to performing any diagnostics or service, the DEF fluid level should be verified that the fluid level does not exceed the recommended fill level. Using a “fuel type” nozzle system with an automatic shutoff or containers that utilize a spout with a seal and an internal vent such as Motorcraft® DEF or equivalent will prevent overfilling. It may be necessary to drain the DEF tank following the procedure in Workshop Manual 308-08 and refilling it to verify the proper level. It is important that the operator follow the DEF tank fill procedure in the Owner Guide.
6591 - 2011-2014 - F-Super Duty - 6.7L Diesel - Diagnostic Trouble Codes (DTC) P20C0 P20C1, P20C2, P20BA, P20BB, P20BC, P20BD, P20BE
Some 2011-2014 F-Super duty vehicles equipped with a 6.7L Diesel engine may exhibit DTCs P20C0, P20C1, P20C2, P20BA, P20BB, P20BC, P20BD or P20BE stored in Powertrain Control Module (PCM) memory. Clear DTCs stored in PCM memory and perform Key On Engine Off (KOEO) Self-Test and Key On Engine Running (KOER) Glow Plug Monitor Self-Test. If reductant heater DTCs are present then perform Pin Point Test 'RH' per the Powertrain Control/Emission Diagnostics (PC/ED). If Glow Plug Control Module (GPCM) DTCs are present then perform Pin Point Test 'AF' per the (PC/ED). If no DTC's return during these tests, no further diagnosis is necessary. Use available service labor times.
6590 - 2011-2014 - F-Super Duty - 6.7L Diesel - Malfunction Indicator Light (MIL) On With Diagnostic Trouble Code (DTC) P20BD And/Or P20BE
Some 2011-2014 F-Super Duty 6.7L diesel equipped vehicles may experience a MIL on with DTC P20BD and/or P20BE due to a damaged heated diesel exhaust fluid (DEF) reductant tube. Inspect the tube for damage, that may have occurred during transportation/shipment, along the outside of frame rail ahead of rear tire(s). If damage is found, replace the DEF reductant tube, base part number (5J249), as required. Warranty claims should be claimed under the transportation damage guidelines as per the warranty and policy manual. If no damage is found, proceed with normal diagnostics.
6589 - 2011-2014 - 6.7L Diesel - Diesel Exhaust Fluid (DEF) Warning Chain Information
6.7L diesel customers may inquire about the Distance to Empty (DTE) Message for the DEF system. Refilling of the tank with the proper quantity of DEF is essential to allow the vehicle to clear the DTE message. Adding up to 2.5 gallons of DEF may be required for the system to detect a refill event. Generally, the DEF tank should be filled during the oil change interval. Driving conditions that increase fuel consumption will also increase DEF consumption and will require additional fills between service intervals. If the DTE message is displayed and no codes are present, verify the Reduct_TNK_LV PID with IDS. If it reads less than 100%, DEF must be added. If the message doesn’t clear after the PID reads 100%, run the IDS SCR System Refill Activation routine.
6588 - 2013-2014 F-Super Duty - 6.7L Diesel - Diagnostic Trouble Codes (DTC) P2201, P229E, P06EA, P06EB, P22A7, P220F - NOx Sensor And Module Replacement
Some 2013-2014 F-Super Duty vehicles equipped with a 6.7L Diesel engine may exhibit the Malfunction Indicator Light (MIL) on with DTC(s) P2201, P229E, P06EA, P06EB, P22A7, P220F. If any of these DTCs are present, replace the NOx sensor and NOx module as a matched set. Do not discard the old parts as they will be called back for returned part anylisis. Engineering is currently investigating this condition, monitor Oasis for updates.
6578 - 2011-2014 - F- Super Duty - 6.7L Diesel - Diesel Exhaust Fluid (DEF) Testing For Petroleum Contamination
2011-2014 F-Super Duty with 6.7L Diesel the DEF test strips are now available from Rotunda under part number 328-44-863 or 328-00012. These test strips can be used to detect petroleum based contamination of the DEF fluid when diagnosing DEF related system DTCs where fluid quality concerns are suspected. DEF system failures that are caused by petroleum based contamination require that the entire DEF system be replaced including the pump, heater assembly, tank, injector and all DEF lines. Cleaning and reusing contaminated DEF system components will result in repeat repairs. Damage resulting from the use of contaminated or improper fluids are not covered under warranty. Refer to the Warranty Policy Manual for additional information.
6577 - 2011-2014 - F-Super Duty - 6.7L Diesel - Checking Diesel Exhaust Fluid (DEF) At Pre-Delivery Inspection (PDI)
2011-2014 - F-Super Duty with 6.7L Diesel equipped vehicles use a selective catalytic reduction (SCR) system designed to reduce the vehicles exhaust emissions. The Diesel Exhaust Fluid (DEF) tank is filled to specification at the assembly plant. Dealers are not instructed to check the DEF fluid on the Pre-Delivery Inspection (PDI) Service Record (check sheet) and are therefore not authorized to top-off the tanks during PDI. The vehicle instrument cluster message center is designed to indicate when the DEF is low (EXHAUST FLUID LOW or EXHAUST FLUID EMPTY). The SCR system should be investigated for repair at PDI only if the instrument cluster message center indicates that there is DEF system fault or low fluid level.
Sep 04 2013 6556 -2011-2014 F-Super Duty - 6.7L Diesel - Updated Service Procedure for Reductant Pump Assembly Replacement
When replacing a Reductant Pump Assembly on 2011-2014 F-Super Duty vehicles equipped with a 6.7L diesel engine, use the latest on-line version of the Workshop Manual, section 303-08. This procedure has been revised to include specific cleaning instructions to prevent dirt from entering the diesel exhaust fluid (DEF) system while servicing the reductant pump.
Aug 30 2013 6544 -2008-2010 - F-Super Duty - 6.4L Diesel - Front Crankshaft Seal Service Procedure Update
For 2008-2010 F-Super Duty vehicles equipped with a 6.4L diesel engine, WSM section 303-01C, In-Vehicle Repair has been updated with the corrected service procedure for replacement front crankshaft seals equipped with flanged wear sleeves. It is imperative that this new procedure be used when installing the latest crankshaft front seals. Note: It is necessary to utilize the plastic spacer ring (packaged with each service seal kit) to ensure the wear sleeve flange does not contact the seal after installation. Failure to follow this service procedure will result in premature failure of the seal.
Aug 29 2013 6533 -2011-2014 F-Super Duty - 6.7L Diesel - Runs Rough With Malfunction Indicator Lamp (MIL) On And Diagnostic Trouble Code (DTC) P0087
Some 2011-2014 F-Super Duty 6.7L diesel equipped vehicles may exhibit an illuminated MIL and DTC P0087 associated with a rough idle condition. If this condition is present, inspect fuse 33 in the Battery Junction Box (BJB) for an open condition. If the fuse is open, replace the fuse and re-evaluate the concern. If the fuse is not open or any DTC's other than P0087 are present, follow normal PC/ED diagnostics.
Aug 23 2013 6510 -2010-2013 F-150 / 2011-2014 F-Super Duty equipped with 6.2L - Power Balance Loss of RPM Contribution on Cylinders 4 And 7.
Some 2010-2013 F-150 and 2011-2014 F-Super Duty equipped with 6.2L may show a loss of rpm contribution on both cylinder number 4 and 7 while performing the integrated diagnostic system (IDS) power balance test. If no misfires are felt and no diagnostic trouble codes (DTC) or mode 6 misfire counts are present to support a misfire on these 2 cylinders, the condition is normal of engine dynamics and how power balance interprets this information. This condition does not affect the function or durability of the vehicle; continue with normal powertrain control/emissions diagnosis (PC/ED) diagnostics and testing.
Aug 23 2013 6509 -2011-2014 F-Super Duty - 6.7L Diesel - Malfunction Indicator Light (MIL) On with Diagnostic Trouble Codes (DTC) P20BC, P20C0, P204C, P208A, P208B, P220E
Some 2011-2014 6.7L diesel equipped vehicles may the MIL on with any combination of the DTC's P20BC, P20C0, P204C, P208A, P208B and/or P220E. These DTC's typically set due to a loose, missing, modified or damaged ground G400. During vehicle modifications, G400 may be relocated by the body builders/outfitters from it's original location. Inspect G400 to ensure it is present, properly secured, clean, and that the bolt head has not broken off prior to performing normal diagnostics. G400 should be located on a main frame rail and not on a cross-member or welded extension. Repairs performed due to vehicle modifications are not covered under normal vehicle manufacturers warranty.
Aug 21 2013 6496 -2011-2014 - 6.7L Diesel - Diesel Exhaust Fluid (DEF) Usage
6.7L diesel customers may inquire about diesel exhaust fluid (DEF) usage/range. Generally, the DEF tank should be filled during the oil change service interval. Driving conditions that affect fuel consumption such as heavy loading, towing, hilly terrain, extended idling will result in increased DEF fluid consumption and may require additional DEF fluid between service intervals. Proper refilling of the DEF tank is essential to prevent additional DEF fluid refills. Pick-up vehicles have a 5.1 gal (19.3 ltrs) capacity and chassis cab vehicles have a 6.2 gal (23.5 ltrs) capacity. Tip: If the message center enters a distance to empty countdown, verify the DEF tank level with the IDS and fill the tank with DEF until the Reduct_TNK_LV PID reads 100% and then perform the SCR Refill Activation on IDS to exit the countdown.
Aug 20 2013 6490 -2011 F59 Commercial Chassis/F53 Motorhome Chassis - Loss Of Power To Upfitter Installed Systems And Accessories
See TSB: 13-08-06 for details.
Aug 16 2013 6483 -2011-2014 F-Super Duty - 6.7L Diesel - High Pressure Fuel System Service Kit
A High Pressure Fuel System Service Kit is now available for 6.7L Diesel equipped vehicles for instances when the high pressure fuel system requires replacement due to contamination (Kit number EC3Z-9B246-A). This kit includes the High Pressure Pump (HPP), High Pressure fuel rails, all eight fuel injectors, injector return lines, engine mounted high pressure fuel lines and the HPP fuel supply lines (Fuel temperature and Fuel pressure sensors included). When the high pressure fuel system becomes contaminated with metal, diesel exhaust fluid (DEF), gasoline or other contaminates, it is extremely important that all of these components are replaced. For further information on diesel fuel system contamination and repair procedures, please reference the 6.7L Diesel Fuel System Service Tips Job Aid located on PTS under Service Tips.
Aug 16 2013 6482 -2011-2014 - F-Super Duty - 6.7L Diesel - Updated Fuel System Job Aid Released
A revised 6.7L Diesel Fuel System job aid titled "6.7L Diesel Fuel System Service Tips" is now available under the Service Tips tab for 2011-2014 6.7L equipped Super Duty vehicles. The information provided in this job aid can assist in identifying the root cause of High Pressure fuel system failures and will aid in determining warrantability if the fuel in the system has been contaminated. When used in conjunction with the work shop manual, PC/ED, and proper diagnostic procedures this job aid can assist in preventing repeat fuel system failures. Identifying the root cause of a fuel system failure is critical in identifying the proper repair direction and preventing subsequent failures of newly installed components.
Aug 12 2013 6461 -2011-2014 F-Super Duty - 6.7L Diesel - Engine Fluid Leak Diagnostic Service Tip
Some 2011-2014 F-Super Duty 6.7L diesel engine equipped vehicles may exhibit fluid leaks that appear to be coming from the front cover and/or from the transmission bellhousing area. The leaks may be due to oil, coolant or other fluids collecting in the engine valley and draining out of the front engine valley drain port or out of the rear engine valley. Prior to performing normal fluid leak diagnostics it is recommended to inspect the engine valley to ensure that no fluids have collected in this area. If coolant or oil is found in the engine valley, closely inspect the turbocharger coolant lines, the turbocharger pedestal and the engine block plugs at the rear of the valley for the source of the leak.
Aug 08 2013 6444 -2011-2012 F-Super Duty - 6.7L Diesel - Updated Diagnostics for Diagnostic Trouble Code (DTC) P2073
When diagnosing/repairing a P2073 DTC on a 2011-2014 6.7L diesel equipped Super Duty vehicles, use the on-line version of the PC/ED Manual, Pin Point Test J. Pin Point Test J has been receintly updated in Section 5 of the on-line PC/ED.
Aug 07 2013 6436 -2011-2014 F-Super Duty - 6.7L Diesel - Malfunction Indicator Light (MIL) On with Various GPCM, Exhaust Reductant System or NOx Control Module DTC’s
Some 2011-2014 6.7L diesel equipped vehicles may exhibit various MIL DTC's related to the glow plug control module (GPCM), the exhaust reductant system or the NOx control module due to a loose, missing, modified or damaged ground G400. During vehicle modifications, G400 may be relocated by the body builders/outfitters from it's original location. Inspect G400 to ensure it is present, properly secured, and that the bolt head has not broken off prior to performing normal diagnostics. G400 should be located on a main frame rail and not on a cross-member or welded extension. Repairs performed due to vehicle modifications are not covered under normal vehicle manufacturers warranty.
Aug 07 2013 6435 -2011-2014 F-Super Duty - 6.7L Diesel - Diagnostic Trouble Codes (DTC) P20E8, P202D and/or P207F - Diesel Exhaust Fluid (DEF) Testing For Petroleum Contamination
Some 6.7L Diesel equipped vehicles may exhibit the Malfunction Indicator Light (MIL) on with DTC(s) P20E8, P202D and/or P207F. These DTCs may be caused by contamination of the DEF from a petroleum based product such as diesel fuel. Visual inspections can be a good indicator as petroleum based products will cause the rubber seals and O-rings in the system to swell and/or leak. If the DEF is suspected of contamination, use the Rotunda DEF test strips (part number 328-00012 or 328-44-863) to check for the presence of petroleum. DEF system failures that are caused by petroleum based contamination require that the entire DEF system be replaced including the pump, heater assembly, tank, injector and all DEF lines. Cleaning and reusing contaminated DEF system components will result in repeat repairs.
Aug 06 2013 6429 -2013 F-Super Duty 650 - 6.8L Engine - Accessory Drive Belt Concerns
See TSB: 13-08-04 for details.
 Aug 02 2013 6417 -2011-2014 F-Super Duty - 6.7L Diesel - Tick/Tap Noise At Idle
Some 2011-2014 F-Super Duty 6.7L diesel equipped vehicles may exhibit a ticking noise at idle after an engine oil change. It is often referred to as Typewriter Noise because of its similarity to the sound of a mechanical typewriter. When engine temperatures reach 150 °F (65 °C) or higher, (from engine idle up to approximately 1700 RPM's), this noise can typically be heard at the front wheel well and is often isolated to the transmission bell housing or oil pan area. Typewriter Noise is not detrimental to engine function or durability and has no short or long term effects on the engine. Do not attempt repairs to eliminate this noise. This noise is characteristic of the 6.7L diesel engine and will typically cease or diminish significantly within the oil change maintenance interval.
Aug 02 2013 6416 -2011-2014 F-Super Duty - 6.7L Diesel - Check Coolant Additive Warning Message - Service Tip
2011-2014 F-Super Duty vehicles equipped with a 6.7L diesel engine require periodic cooling system maintenance at intervals around 15,000 miles (24,000 KM) or 600 engine hours, whichever occurs first. Vehicles equipped with the optional message center will display "Check Coolant Additive" when service is required. This message is indicating the cooling system should be tested and is not a direct indicator that the coolant needs to be replaced or that the system needs to be flushed. Use Rotunda test kit #328-00001 and 328-00008 or equivalent to properly test for Nitrate contamination and corrosion inhibitor level. Refer to WSM section 303-03B for details on testing the coolant and section 413-01 for resetting the maintenance reminder. Owners can refer to the diesel owner guide supplement for additional information.
Aug 02 2013 6415 -2011-2014 F-Super Duty - 6.7L Diesel - Diesel Fuel Conditioning Module (DFCM) Vibration/Buzzing/Growl - At Or Below 1/4 Tank Of Fuel
Some 2011-2014 F-Super Duty vehicles equipped with a 6.7L diesel engine may exhibit a vibration/buzz/growl noise from the DFCM and/or low pressure fuel lines when operating the vehicle with the fuel tank at 1/4 level or below. This should be considered a normal characteristic and is due to slight amounts of air entering the fuel system during lower fuel level conditions. No repairs should be attempted. Fuel system and vehicle durability as well as vehicle drivability and distance to empty (DTE) are not affected.
Jul 31 2013 6408 -2013 - 6.7L - Malfunction Indicator Light (MIL) On - DTCs P2002, P208E, P06EA - Exhaust Fluid System Fault - Forced Idle - Vehicles Built On Or Before 5/13/2013
See TSB: 13-07-12 for details.
Jul 08 2013 6307 -2013 F-Super Duty Equipped With 6.2l Gas Or 6.7l Diesel Engine With 6R140 Transmission - PTO Noise Normal Characteristic
Some 2013 F-Super Duty vehicles equipped with a 6.2l or 6.7l engine and 6R140 transmission may exhibit a noise upon installation of a power take off (PTO). The noise (rattle, chatter, etc) only occurs when the PTO is not engaged and goes away with increased engine speed. The noise does not indicate a problem with the PTO or the transmission. It is the result of the engine firing pulses being transferred into the PTO gear train. The noise will vary between truck chassis, engines, transmissions and PTO manufacturer's due to the stiffness of the system's as well as the variation in the components. It does not affect the performance or durability of the truck or the PTO. This is a normal PTO characteristic and repairs should not be attempted.
Jun 19 2013 6236 -Multi Vehicle Line - Receiver Dryer Cartridge Service Part Design Change
During the 2013 calendar year, 2011- 2013 F-SuperDuty, 2009-2013 F150, 2007-2013 Expedition,Navigator vehicles along with service parts will be transitioning to the new 2 piece bag style receiver dryer replacing the 1 piece receiver dryer cartridge. These two designs are fully interchangeable and does not affect fit, form, or function. Continue to follow Workshop Manual section 412-01 on the Removal and Installation of the Receiver Drier Cartridge. The desiccant bag goes in first then the cartridge and cap.
Jun 13 2013 6196 -2013 - F-Super Duty - 6.7L Diesel - PTO Disengagement With Vehicle Body Movement - Built On Or Before 5/14/2013
See TSB: 13-06-14 for details.
Jun 10 2013 6178 -2011-2013 E-Series - 5.4L 2V and 6.8L 2V Engine - Excessive Engine Oil Consumption
See TSB: 13-06-09 for details.
May 30 2013 6134 -2011-2013 F-Super Duty - TorqShift6 Automatic Transmission - Band 1 Solenoid Kits - Now Available
2011-2013 F-Super Duty vehicles when normal diagnostics lead to transmission solenoid replacement where a Band 1 solenoid is used, replacement of the (7A100) main control assembly is no longer necessary. Band 1 solenoid kits have been released for service and the part catalog has been updated.
May 17 2013 6076 -2012-2013 F650 and F750 PTO Installation and Operation
Information regarding 2012-2013 F650 and F750 Power-Take-Off (PTO) installation and operation can be found in Bulletin Q-215 on the Ford Fleet website. Refer to www.fleet.ford.com>Showroom>Truck Body Builders/Upfitters>Bulletins>Q-215.
May 07 2013 6018 -2011-2013 - 6.7L Diesel - Malfunction Indicator Light (MIL) On with Various GPCM, Exhaust Reductant System or NOx Control Module DTC’s
Some 2011-2013 6.7L diesel equipped vehicles may exhibit various MIL DTC's related to the glow plug control module (GPCM), the exhaust reductant system or the NOx control module due to a loose, missing, modified or damaged ground G400. During vehicle modifications, G400 may be relocated by the body builders/outfitters from it's original location. Inspect G400 to ensure it is present, properly secured, and that the bolt head has not broken off prior to performing normal diagnostics. G400 should be located on a main frame rail and not on a cross-member or welded extension. Repairs performed due to vehicle modifications are not covered under normal vehicle manufacturers warranty.
May 03 2013 6008 -2011-2013 F- Super Duty - 6.7L Diesel - Engine Fluid Leak Diagnostic Service Tip
Some 6.7L diesel engine equipped vehicles may exhibit fluid leaks that appear to be coming from the front cover and/or from the transmission bellhousing area. The leaks may be due to oil, coolant or other fluids collecting in the engine valley and draining out of the front engine valley drain port or out of the rear engine valley. Prior to performing normal fluid leak diagnostics it is recommended to inspect the engine valley to ensure that no fluids have collected in this area. If coolant or oil is found in the engine valley, closely inspect the turbocharger coolant lines, the turbocharger pedestal and the engine block plugs at the rear of the valley for the source of the leak.
May 03 2013 6006 -2011-2013 F-Super Duty - 6.7L Diesel - Turbo Noise Characteristics
Some 2011-2013 F-Super Duty 6.7L diesel equipped vehicles may experience a characteristic turbo spool-down (hoot) noise on throttle tip-out when the engine oil temperature (EOT) is below 150F (65C) and/or an oscillating turbo whine at idle when the EOT is below 50F (10C). 6.7L diesel engines include improvements designed to reduce overall inherent diesel engine noises. Sound reduction improvements enable certain characteristic noises to be more easily heard. Using incorrect engine oils for the vehicles operating conditions can negatively impact the level of noise experienced. Refer to the vehicles owner/maintenance guides for proper engine oil usage information. Customers should be informed that these noises do not affect engine durability and should be considered characteristic and no repairs are necessary.
Apr 29 2013 5992 -2008-2013 F-SUPER DUTY equipped with Four Wheel Drive (4WD) Front Suspension - Track Bar Bushing Available Separate from Track Bar Assembly.
2008-2013 F-Super Duty vehicles equipped with four wheel drive(4wd) front suspension, the front track bar bushing (base part #3A116) is now available for service and is separate from the track bar assembly (Base part # 3b239). For diagnostic and repair information, refer to updated on-line workshop manual section 204-01b and use available service labor times standards (SLTS) operations.
Apr 12 2013 5932 -2011-2013 F-Super Duty - 6.7L - Fuel System Repair/Replacement Due To Fuel System Contamination
Some 2011-2013 F-Super Duty vehicles equipped with the 6.7L Diesel engine may exhibit one or more of the following conditions: crank no start, extended crank hard start, runs rough, low power, engine knocking, exhaust smoke, slow to build or low fuel rail pressure (FRP). These concerns may be caused by contaminated fuel. Refer to the diesel fuel system contamination diagnosis and service procedure job aid available on PTS or FMCDealer.com. Damage to the fuel system caused by contaminated fuel is not warrantable and may be subject to charge back. Please see the Warranty and Policy manual for further information.
Apr 12 2013 5931 -2011-2012 F-Super Duty - 6.7L - Diesel Fuel Conditioning Module (DFCM) Service Tip Job Aid
6.7L Diesel Fuel Conditioning Module (DFCM) are being replaced due to audible noises that can resonate through the fuel lines. Engineering review has found that DFCM noise is not typically a concern with the DFCM itself but a result of air ingress or restrictions in the fuel system. A 6.7L DFCM Noise/Repair Job Aid is available on PTS to assist with identifying the most common sources of air ingress or restrictions in the fuel system. This job aid also contains tips for fuel filter replacement and fuel system bleeding.
Apr 11 2013 5921 -2011-2013 - 6.7L Diesel - Diesel Exhaust Fluid (DEF) Testing For Petroleum Contamination
DEF test strips are now available from Rotunda under part number 328-00012 or 328-44-863. These test strips can be used to detect petroleum based contamination of the DEF fluid when diagnosing DEF related system DTCs where fluid quality concerns are suspected. The PC/ED is in the process of being updated to include the use of the test strips. DEF system failures that are caused by petroleum based contamination require that the entire DEF system be replaced including the pump, heater assembly, tank, injector and all DEF lines. Cleaning and reusing contaminated DEF system components will result in repeat repairs. Damage resulting from the use of contaminated or improper fluids are not covered under warranty. Refer to the Warranty Policy Manual for additional information.
Apr 11 2013 5919 -2011-2012 Motorhome And Commercial Chassis - MIL And Wrench Lamp - Battery Junction Box Fuse 3 Open - Built On 1/19/2010 And Through 12/18/2012
See TSB: 13-04-08 for details.
Apr 08 2013 5894 -2011-2012 -6.7L Calibration Update - Engine Shudder/Surge With Or Without Turbo Flutter Noise During Steady Throttle 900-1400 RPM - Built On Or Before 5/16/2012
See TSB: 13-04-03 for details.
Apr 05 2013 5887 -2011-2012 F-650/F-750 -€6.7L Cummins - No Crank/No Start With No Diagnostic Trouble Codes (DTCs)
Some 2011-2012 F-650 and F-750 vehicles equipped with a 6.7L Cummins engine may exhibit a no crank/no start condition with no DTCs. If determined to be the result of the starter ring gear separating from the flex plate, repairs must be performed by a Cummins certified repair facility. Refer to Warranty and Policy Manual, Section 3 for warranty coverage information on Cummins components and F-650 - Higher Series vehicles. If vehicle cannot be moved to a Cummins Certified Repair Facility, reference the Cummins Temporary Repair Practice (TRP) T1331, located on the Cummins RapidServe website.
Mar 22 2013 5818 -F53 and F59 Steering Clear Vision Adjustment
SOME F53 MOTORHOME AND F59 COMMERCIAL CHASSIS VEHICLES MAY EXHIBIT STEERING SYSTEM CLEAR VISION CONCERNS. CLEAR VISION CONCERNS CAN BE CORRECTED BY RE-INDEXING THE STEERING SHAFT TO STEERING GEAR CONNECTION. REFER TO THE STEERING COLUMN SHAFT - MOTORHOME PROCEDURE WORKSHOP MANUAL SECTION 211-04 STEERING SYSTEM. OTHER STEERING OR SUSPENSION CONCERN SHOULD BE ADDRESSED USING THE WORKSHOP MANUAL.
Mar 22 2013 5817 -2013 F-Super Duty - 6.7L - Diagnostic Trouble Code (DTC) P2002 Setting On Low Mileage Vehicles
Some 2013 F-Super Duty vehicles equipped with a 6.7L diesel engine may exhibit MIL on with Diagnostic Trouble Code (DTC) P2002 only with less than 5000 miles (8000 km). Performing Pin Point Test (PPT) RB, it may lead to SCR system replacement. Before replacing the SCR system, carry out the Diesel Particulate Filter Parameter Reset function on the IDS scan tool. Refer to section 2 of the PC/ED, Resetting The Diesel Particulate Filter Parameter. If no DTCs return, release the vehicle to the customer. If DTCs other than P2002 are present, follow the appropriate PPT for those DTCs. Replacement of the DPF for a P2002 code should only occur when there is soot present in the tailpipe. Engineering is currently investigating the concern. Monitor Oasis for updates.
Mar 19 2013 5802 -6.7L - Exhaust Gas Recirculation (EGR) Cooler Core Replacement - Work Shop Manual (WSM) Update
WSM section 303-08 disassembly and assembly "Exhaust Gas Recirculation (EGR) Cooler - 6.7L Diesel" has been updated. It is no longer required to remove the EGR valve from the throttle plate when replacing the EGR cooler core. Also the EGR valve gasket will be removed from the EGR seal kit due to it is no longer required when replacing the EGR cooler core.
Mar 15 2013 5791 -6.7L Diesel - Tick/Tap Noise At Idle
Some 6.7L diesel equipped vehicles may exhibit a ticking noise at idle after an engine oil change. It is often referred to as Typewriter Noise because of its similarity to the sound of a mechanical typewriter. When engine temperatures reach 150 °F (65 °C) or higher, (from engine idle up to approximately 1700 RPM's), this noise can typically be heard at the front wheel well and is often isolated to the transmission bell housing or oil pan area. Typewriter Noise is not detrimental to engine function or durability and has no short or long term effects on the engine. Do not attempt repairs to eliminate this noise. This noise is characteristic of the 6.7L diesel engine and will typically cease or diminish significantly within the oil change maintenance interval.
Mar 15 2013 5790 -2011-2012 F-Super Duty - 6.7L - Runs Rough/Misfire During Regeneration
Some 2011-2012 F250-450 Super Duty Pickup trucks equipped with a 6.7L diesel engine may exhibit a runs rough/misfire concern during regeneration. This concern does not result in diagnostic trouble codes setting and does not apply to chassis cab vehicles. This concern is currently under engineering investigation. Do not attempt to repair this concern at this time. Please monitor Oasis for future updates.
Mar 13 2013 5778 -2011-2013 F-250 Super Duty 4x4 - Rear Of Vehicle Sits Lower Than Expected Under Light Loads
See TSB: 13-03-08 for details.
Mar 12 2013 5766 -6.7L Diesel - Diagnostic Trouble Codes (DTC) P20C0 And/Or P20C1, P20C2, P20BA, P20BB, P20BC, P20BD, P20BE
Some 2011-2013 F-Super duty vehicles equipped with a 6.7L Diesel engine may exhibit DTCs P20C0, P20C1, P20C2, P20BA, P20BB, P20BC, P20BD or P20BE stored in Powertrain Control Module (PCM) memory. Clear DTCs stored in PCM memory and perform Key On Engine Off (KOEO) Self-Test and Key On Engine Running (KOER) Glow Plug Monitor Self-Test. If reductant heater DTCs are present then perform Pin Point Test 'RG' per the Powertrain Control/Emission Diagnostics (PC/ED). If Glow Plug Control Module (GPCM) DTCs are present then perform Pin Point Test 'AF' per the (PC/ED). If no DTC's return during these tests, no further diagnosis is necessary. Use available service labor times.
Mar 05 2013 5735 -2013 F-Super Duty Pickups - Tailgate cable change
2013 F-Super Duty Pickup tailgate cables are shorter than the tailgate cables used on 2012 F-Super Duty Pickups to accommodate the new Platinum series tailgate applique. All 2013 units get the shorter cables. When on a level surface the shorter cables will raise the tailgate more above level in relationship to the bed floor that seen on a 2012 like unit. This is a normal operation of the tailgate, if a functional concern is present, refer to work shop manual section 501-00.
Mar 05 2013 5734 -2013 F-Super Duty Erratic Operation Of One Touch Auto Up/Down Power Window Feature
2013 F-Super Duty vehicles with One Touch auto up / down power windows may exhibit erratic operation with possibility of a different window(s) being inoperative after each key cycle. Check for possible aftermarket equipment added to the accessory delay circuits of the Body Control Module (BCM). Splicing into the accessory delay circuits can cause voltage to drop, when the ignition key is turned on resulting in power window motor(s) to be inoperative for a key cycle. Refer to Warranty and policy manual for Aftermarket accessories policies. If no aftermarket accessories are present and/or a functional operation is suspect, refer to workshop manual section (WSM) 501-11 ford diagnostics and repairs.
Mar 04 2013 5729 -6.4L - High Pressure Fuel System Debris Test With Less Than 100 psi of Fuel Rail Pressure (FRP)
Some 2008-2010 F-super Duty vehicles equipped with a 6.4L diesel engine may require the fuel system debris check to be performed per the Powertrain Control/Emissions Diagnostic (PC/ED) > Section 4, hard start/no start > step 28. This test requires fuel flow from the high pressure pump (HPP) to push debris out of the fuel rails for inspection. If you have less than 100 psi change in FRP while cranking with good base fuel pressure (3-8psi) then the HPP may not have adequate flow to perform the debris test requiring the high pressure fuel rails to be removed and flushed with clean diesel fuel to obtain a sample. Note: Removing the fuel rails is not required to perform the debris test when fuel flow is present while cranking.
Feb 27 2013 5713 -2011-2013 F-Super Duty Equipped With Optional Information And Message Center. Trip A Or B Odometer Reset Or Orange Rectangle Box Displayed
Some 2011-2013 F-Super Duty equipped with optional Instrument Cluster information display may exhibit a trip odometer Trip A or Trip B with orange rectangle box over the cluster screen during reset operation. These conditions may occur when press and release Info/Ok button on the steering wheel multiple times or quickly to pause/un-pause Trip A/B. To reset, press and hold Info/OK button, also following the owner guide under instrument cluster optional information display section for Trip A/B. If a functional issue does exist, refer to updated Workshop Manual Section (WSM)section 413-01 for normal diagnostics and repairs.
Feb 15 2013 5662 -2011-2013 F-Super Duty - Updated Workshop Manual - Climate Control Diagnostics And Testing - Service Tip
When diagnosing climate control conditions on 2011-2013 F-Super Duty vehicles, use the updated online version of the Workshop Manual (WSM). Climate Control Diagnostics And Testing has been updated in (WSM) Section 412-00. Note: If the vehicle has add-on remote start system, ensure to follow (WSM) section 412-00 under description and operation of remote start system behavior. During remote start, the outside air temperature is continually evaluated and Heating Ventilation Air Conditioning (HVAC) system behavior or blower motor operation can change, if the outside air changes between cold, moderate and warm temperatures. These system behavior operation(s) are consider normal operation of the HVAC system.
Feb 15 2013 5661 -2013 F-Super Duty Equipped With Platinum Package - Rear Tailgate Applique Peeling, Bubbling And/Or Blister - Built On Or Before 02/08/2013
Some 2013 F-Super Duty vehicles equipped with platinum package built on or before 02/08/2013 may exhibit a blister, peeling or bubbling condition on the rear tailgate applique. New service parts # DC3Z-99425A34-A is release to address the concern. Follow prior approval on PTS and/or FMCDEALER.COM.Refer to online version of the Workshop Manual Section (WSM) 501-08
Feb 04 2013 5612 -2013 F-Super Duty - 6.7L Diesel - "Exhaust Fluid System Fault" Warning
Some 2013 F-Super Duty vehicles equipped with the 6.7L diesel engine may exhibitan "Exhaust Fluid System Fault" warning in the instrument cluster message centerwith no DTC’s present in PCM memory. If DTC’s are present perform the appropriate PC/ED diagnostics. If no DTC’s are present or if DTC’s have been repaired the message can be cleared by driving the vehicle for up to 10 minutes at a steady speed of at least 30 miles per hour with the engine at normal operating temperature. If no fault is present the message will not return. This concern is currently under investigation by Engineering and is not caused by a fault with the instrument cluster message center.
Jan 28 2013 5590 -6.7L - Workshop Manual (WSM) Update - Upper Oil Pan Plug Torque Specification
The gold colored upper oil pan plug (W528210-S437) previously known as the zero leak plug is now serviceable. WSM section 303-01C specifications have been updated to include the upper oil pan torque specification. Replacement of the upper oil pan is no longer required to repair a leaking upper oil pan plug.
Jan 25 2013 5585 -6.7L Diesel - MIL 'On' With Diagnostic Trouble Code (DTC) P20BD And/Or P20BE
Some 2011-2013 F-Super Duty 6.7L diesel equipped vehicles may experience a MIL on with DTC P20BD and/or P20BE due to a damaged heated diesel exhaust fluid (DEF) reductant tube. Inspect the tube for damage, that may have occurred duringtransportation/shipment, along the outside of frame rail ahead of rear tire(s). If damage is found, replace the DEF reductant tube, base part number (5J249), asrequired. Warranty claims should be claimed under the transportation damage guidelines as per the warranty and policy manual. If no damage is found, proceedwith normal diagnostics.
Jan 25 2013 5584 -6.7L Diesel - MIL 'On' After Body Modifications
Some 2011-2013 6.7L diesel equipped vehicles may exhibit various MIL DTC’s related to the glow plug control module (GPCM), the exhaust reductant system or the NOx control module due to a loose, missing or modified ground at G400. During vehicle modifications, module damage can also occur from not isolating these modules during welding operations by body builders/outfitters. It is advisable to inspect G400 and vehicle equipment installations prior to performing normal diagnostics as these types of repairs may not be covered undernormal vehicle manufacturers warranty.
Jan 14 2013 5539 -2011-2013 F-Super Duty - Parts Available For Dealer Installation Of Tow command System
TO INSTALL A TRAILER BRAKE CONTROLLER (TBC) ON A 2011-2013 F-SUPER DUTY THAT WAS NOT ORIGINALLY EQUIPPED FROM THE FACTORY, ORDER A TBC MODULE BC3Z-2C006-C, AND AN INSTRUMENT PANEL (IP) BIN (8C3Z-2513546-CA). NOTE: THE INSTRUMENT CLUSTER MUST ALSO BE PROGRAMMED USING IDS SOFTWARE RELEASE 82.01 OR HIGHER. REFERENCE WORK SHOP MANUAL SECTION (WSM)206-10 FOR ADDITIONAL INFORMATION OR IDS SCREENS TO ENABLE TBC FUNCTIONS. SERVICE TIPS: REPLACEMENT OF THE MASTER CYLINDER IS NOT REQUIRED ON SINGLE REAR WHEEL DRIVE UNITS (SRW)(UNLIKE 2005-2010 F-SUPER DUTY MODEL YEARS),ONLY DUAL REAR WHEEL (DRW) CHASSIS CAB UNITS INCLUDE A PRESSURE TRANSDUCER BELOW THE MASTER CYLINDER, AND TBC MODULE CONNECTORS ARE LOCATED BEHIND OR UNDERNEATH THE INSTRUMENT PANEL RADIO BEZEL WHERE TBC IP BIN IS INSTALLED.
Jan 08 2013 5521 -2011-2012 F-Super Duty - TorqShift6 Transmission - Delayed Engagement In Drive Or Reverse - Built On Or Before 9/30/2012
See TSB: 13-01-03 for details.
Jan 03 2013 5506 -2011-2013 F-Super Duty - Servicing Heater Core - Service Tip.
For 2011-2013 F-Super Duty vehicles that may lead to the replacement of the heater core (Base part # 18476) during vehicle life, ensure to follow the updates in work shop manual (WSM) Section 412-01 during diagnosis, removal, and installation. Service Tip: If the repair leads to Heater Core replacement, ensure to replace both inlet/outlet hose clamps and o'rings are replace. Which are part of service kit part # BC3Z-8287-C. Failure to follow this direction from the WSM, may result in damage to the heater core, inlet/outlet hoses or repeat coolant leaks. Follow normal service labor times standard (SLTS) operations for repairs. Clean service stock of heater cores (Base 18476) and o'ring service kits (Base 8287) are available. Refer to DOES II for the latest and greatest part availability.
Jan 03 2013 5505 -2011-2013 F-Super Duty Equipped With Torqshift6 (6R140) - Fluid Pan, Gasket And Filter Service - Service Tip
2011-2013 F-SuperDuty vehicles equipped with torqshift6 (6R140) automatic transmission, the transmission fluid filter (base part # 7A098 ) is now availablefor service ( part # BC3Z-7A098- B ) and is sold separate from transmission fluid pan gasket(base part # 7A191 ). Ford diagnostics, repairs and removal and installation information, refer to updated on-line workshop manual section 307-01B and use available service labor times standards (SLTS) operations. Referto DOES II for the latest and greatest part availability
This topic is now closed to further replies.
