ktmlew Posted January 4, 2013 Share Posted January 4, 2013 The above codes reference a TPS/APP issue. I have done a wiggle test of the wiring. Am i expecting it to stall or just kick a code? Quote Link to comment Share on other sites More sharing options...
sneakypete Posted January 5, 2013 Share Posted January 5, 2013 engine light comes on and goes into reduced power. have had a couple things set this code. pull the conduit back at the tb connector and give each wire a tug. I think it's the yellow wire that likes to break. ground problems at g103 and g104 can set this dtc. when I was at the dealer, the guaranteed fix was a rewire. pcm to tb new terminals end to end. I've seen people have luck with soldering the tb terminals only. also check the freeze frame for a low voltage concern. this will set the dtc's as well. Quote Link to comment Share on other sites More sharing options...
