rlchv70 Posted February 18, 2013 Share Posted February 18, 2013 Working on my personal vehicle in my garage. Not a technician by trade, just a backyard mechanic. Limited experience with A/C systems. A/C doesn't work. A/C clutch won't come on. If I command on with scan tool, it will work. However, still doesn't blow cold. I attached gauge manifold. Has plenty of low side pressure. However, high side pressure is identical to low side pressure, even with compressor on. Scan tool shows pressure sensor reads accurately. Thoughts and ideas? Thanks. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted February 18, 2013 Share Posted February 18, 2013 Plenty of low side pressure is not exactly a good description... low side should be low with the compressor running and considerably lower than the high side. Since you have a manifold gauge, what are your pressures and what is the system pressure with KOEO? The pressure number should be near what the ambient temperature number with a properly charged system is as a general rule. (at least with the Ford systems it works out that way) I suspect that your system charge is low. Ford systems won't cycle at all with low system pressure but I am assuming GM is similar. The fact that you can command the compressor clutch on with a scan tool and that the system does not cool when it is kinda backs up my guess here. Quote Link to comment Share on other sites More sharing options...
mchan68 Posted February 18, 2013 Share Posted February 18, 2013 Just throwing a guess out there, but I vaguely recall some GM products were known to have A/C condensor leaks on a few models of that era. I would check around the outside components to see if there was was evidence of any leaks visually as a start. Quote Link to comment Share on other sites More sharing options...
rlchv70 Posted February 18, 2013 Author Share Posted February 18, 2013 Some additional info: High side and low side pressure are identical even with compressor commanded on. Leak tested entire system with a sniffer. Replaced schrader valve on high side, but issue still persists. I don't remember what the pressure reading was. I'll have to check my notes and reply back. It was higher than the spec for the given ambient temp. Quote Link to comment Share on other sites More sharing options...
Mbl35 Posted February 19, 2013 Share Posted February 19, 2013 Is there a suction throttle valve at the evaporator core or somthing that looks like an H valve used on chrysler stuff? Try whacking it with a hammet and see if the temp drops a little. Quote Link to comment Share on other sites More sharing options...
ktmlew Posted February 19, 2013 Share Posted February 19, 2013 GM disables compressor operation if any A/C codes are in the system. If static LS & HS pressure is in the 70-80psi range then you need to clear the codes first. Quote Link to comment Share on other sites More sharing options...
rlchv70 Posted February 19, 2013 Author Share Posted February 19, 2013 No codes. Quote Link to comment Share on other sites More sharing options...
Aaron Posted February 19, 2013 Share Posted February 19, 2013 If the pressure is the same on both I'd lean towards the A/C compressor not pumping (Shaft broke or compressor just whistled), or the restriction (orifice tube, TXV) not working. Quote Link to comment Share on other sites More sharing options...
mrbudge Posted February 21, 2013 Share Posted February 21, 2013 If the pressures are equal on both sides with the compressor running, the compressor is nfg. I am not a GM guy, but I have seen some vehicles that you can hook up both of your guages to the same side (there are two service ports on one side) and then the pressures will obviously read equal. Even if that is the case the low side should drop and high side should rise as soon as the compressor starts, depending which side you are hooked up to. I will often do the touch test on the discharge side, if the compressor is compressing, the discharge line should be HOT. Quote Link to comment Share on other sites More sharing options...
rlchv70 Posted February 22, 2013 Author Share Posted February 22, 2013 I think it is the compressor. Spun it last night by hand and it was very easy to spin. Quote Link to comment Share on other sites More sharing options...
