First 6R140
I finally had to pull and disassemble a Torqshift-6. Man, everything is big and heavy in that sucker! I think I made a mistake by deciding not to mount the unit in my engine stand but it will likely end up there after I clean the case and go to reassemble. If I had pre-read the WSM instead of reading as I went I probably would not have slapped it on the bench but what a fucking circus though: pull it out with a trans jack... lift it off with an engine hoist then mount it onto a stand. Maybe on the second one I'll have my act together.
Yeah. I pulled the convereter, the pump and the forward/overdrive clutch assembly by hand on the bench. Assembly will be nerly impossible without a hoist and engine stand. These assemblies are just way to big and heavy. I think the risk of damaging something and being injured his high id you don't. Fortunately the tool kits have hoist adapters.
