Buddy_M Posted April 23, 2013 Share Posted April 23, 2013 I only have the IDS/VCM setup and have had a couple older trucks where the OBD-II port under the dash is not active(thankfully the few problems they have had I've been able to diagnose/repair them without the scan tool.) I'm wondering if anyone knows if I can hook up thru the OBD-II connector and if the IDS can be used to program the PCM to the OBDII port and force it to successfully program by a newer tear tag/calibration/part number thru manual entry? Quote Link to comment Share on other sites More sharing options...
Bruce Amacker Posted April 24, 2013 Share Posted April 24, 2013 Probably not. The dealers were having a difficult time programming these and most got new PCMs calibrated to '96. If it is an early one you can talk to it (limited) through the OBD1 connector by the hood hinge. Get a reman/used '96 PCM, (or buy one for that truck, it will be OBD2 out of the box) they're cheap. Good Luck! Quote Link to comment Share on other sites More sharing options...
scott1984 Posted April 24, 2013 Share Posted April 24, 2013 I do know that the vcm 2 has a problem programing older vehicles even some 6.0s. Make sure the are wires going to the obd 2 connector. Also check for power and ground if they are there. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted April 25, 2013 Share Posted April 25, 2013 Holy cow. It seems like the last one of those I saw we were still using SBDS. Quote Link to comment Share on other sites More sharing options...
