6.7 egr cooler failures
 I am seriously considering trying to leave the EBP tube attached to the up pipe on my next one.
Works like a charm.  I started doing that about 3 coolers ago.  I also leave the upper in place, but remove the PCM for access.  Takes longer to drain the cooling systems that it does to remove the cooler now.
I don't drain the secondary cooling system, just clamp off the hoses. I leave the PCM and harnesses intact as well. If you pull the cooler out a bit it's easier to get at the harness.
That was the first thing I noticed on my first one yesterday. Oh well, live and learn. In goes another "6.7L gravy train job" to file away in the memory bank.
