Aaron Posted May 2, 2013 Share Posted May 2, 2013 http://www.liveleak.com/view?i=acc_1367278543 They walk among us. I just find myself wondering what the thought process was here. Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted May 2, 2013 Share Posted May 2, 2013 Dear God in Heaven. Quote Link to comment Share on other sites More sharing options...
YukonTyler Posted May 2, 2013 Share Posted May 2, 2013 There are no words. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted May 2, 2013 Share Posted May 2, 2013 How about FIRE! Quote Link to comment Share on other sites More sharing options...
Alex Bruene Posted May 2, 2013 Share Posted May 2, 2013 And the purpose of continuing to crank the engine AFTER it started on fire was? Quote Link to comment Share on other sites More sharing options...
scott1984 Posted May 2, 2013 Share Posted May 2, 2013 Bet that was hotttt. Dude is very lucky Quote Link to comment Share on other sites More sharing options...
lmorris Posted May 2, 2013 Share Posted May 2, 2013 Wonder if he tried to start it again after spraying all that water down the carb? Quote Link to comment Share on other sites More sharing options...
Aaron Posted May 3, 2013 Author Share Posted May 3, 2013 And the purpose of continuing to crank the engine AFTER it started on fire was? The ONLY thing I can even begin to assemble as a thought for this, is when you have a small carb backfire, and starting the engine and the resulting venturi effect sucks the fire out. And I refer you fellows to this: Quote Link to comment Share on other sites More sharing options...
ktmlew Posted May 3, 2013 Share Posted May 3, 2013 I work for a guy that does mobile heavy equipment repair. We are currently replacing the walking beams on rear susp of a dump truck. They ran it until the RR forward end bushings failed and the beam detached from the housing. The bracket, which is welding to the housing, is killed/spread,. So tomorrow, the boss intends to torch the bracket off the housing with everything still under the truck. Lots of rubber & plastic air hoses in close proximity. I mentioned it would be a good idea to have a working fire extinguisher handy. He said not necessary... You just can't FIX stupid!!! Quote Link to comment Share on other sites More sharing options...
DieselD Posted May 3, 2013 Share Posted May 3, 2013 And the purpose of continuing to crank the engine AFTER it started on fire was? no shit! cause that is going to put the fire out! Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted May 3, 2013 Share Posted May 3, 2013 "Lord, Jesus, theys a fire" Quote Link to comment Share on other sites More sharing options...
jimmy57 Posted May 3, 2013 Share Posted May 3, 2013 Maybe the cranking was so the mechanical fuel pump would push some more fuel onto engine and burn the WHOLE car down. This would have resolved all the problems with that car. Quote Link to comment Share on other sites More sharing options...
mrbudge Posted May 3, 2013 Share Posted May 3, 2013 Darwin was a pretty smart guy..... Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted May 4, 2013 Share Posted May 4, 2013 Darwin was a pretty smart guy..... Not to disagree about Darwin... but... if this was the case here then this kid's dad should have bought the farm working on a Studebaker or his grandfather working on a Model A. Quote Link to comment Share on other sites More sharing options...
Aaron Posted May 4, 2013 Author Share Posted May 4, 2013 Maybe the cranking was so the mechanical fuel pump would push some more fuel onto engine and burn the WHOLE car down. This would have resolved all the problems with that car. If you turn the volume way up, you can hear a regulated Holley Blue singing in the background. Quote Link to comment Share on other sites More sharing options...
Jim Warman Posted May 4, 2013 Share Posted May 4, 2013 Yes, this boy could have been twins. "But, ah sawr them did it on HotRod TV". Quote Link to comment Share on other sites More sharing options...
Aaron Posted May 4, 2013 Author Share Posted May 4, 2013 And only in 22 minutes! Quote Link to comment Share on other sites More sharing options...
Alex Bruene Posted May 4, 2013 Share Posted May 4, 2013 is when you have a small carb backfire, Carb? Like carbohydrate? I don't get it. Quote Link to comment Share on other sites More sharing options...
Aaron Posted May 4, 2013 Author Share Posted May 4, 2013 Originally Posted By: Aaron is when you have a small carb backfire, Carb? Like carbohydrate? I don't get it. Single reverse dinglearm carburizer! Speaking of which, I need to get a gasket set for the puddle-dumper on my hot rod. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted May 5, 2013 Share Posted May 5, 2013 Just like people, too much carb will make your engine get too fat. Quote Link to comment Share on other sites More sharing options...
Aaron Posted May 5, 2013 Author Share Posted May 5, 2013 Just like people, too much carb will make your engine get too fat. Nicely done! Quote Link to comment Share on other sites More sharing options...
Jim Warman Posted May 5, 2013 Share Posted May 5, 2013 And I didn't want to waste these on the "good sayings" thread. There is no replacement for displacement. If some is good, and more is better - then too much ought to be just about enough. Quote Link to comment Share on other sites More sharing options...
