mrbudge Posted May 14, 2013 Share Posted May 14, 2013 Anyone remember how to identify an aftermarket calibration by file name in IDS log viewer? Quote Link to comment Share on other sites More sharing options...
Aaron Posted May 15, 2013 Share Posted May 15, 2013 Some of the aftermarket tuners are identifying their tunes as Ford cals as well, so that's something to look out for. Strategy: and Filename: at the top of the IDS log after the VIN SHOULD tell you the current calibration. PCM_FILENAME: Should also tell you what calibration is in it. I'd compare it to a like unit, and see what the calibration in that unit. Do you figure you've got something tuned? Quote Link to comment Share on other sites More sharing options...
mrbudge Posted May 15, 2013 Author Share Posted May 15, 2013 Ford had sent a message at one time saying what the pcm filename suffix should be if it was a OEM calibration, but now I can't find it. We have a 6.7 here that IDS had no trouble identifying, but when I went to do a reflash it couldn't get valid data from the pcm to start the programming process. I did a PMI and programmed with as built and it all worked good, but flipped on the MIL right after. The EGR valve was siezed shut, but there was no light on before the reflash. Oh well, nothing makes me happier than writing over someone elses aftermarket calibration. Quote Link to comment Share on other sites More sharing options...
lmorris Posted May 16, 2013 Share Posted May 16, 2013 You are in luck. I had to recover a PCM and re-install a tune to get a truck running. Stock PCM CAL: 8U7A-14C204-HCA CVN: AF4E7D69 TCM CAL:8C3A-14C337-DC CVN:CC0D72BD Tuned PCM CAL: 8F716A0533 CVN: 65CBF2FB TCM CAL: 8C3A-14C337-CA CVN: A1B4D0C9 This was an H&S mini max tuner. Quote Link to comment Share on other sites More sharing options...
Aaron Posted May 18, 2013 Share Posted May 18, 2013 It seems the TCM cal in most aftermarket tuners shows as the 8C3A - CA identifier. They're TRYING to make that PCM cal look like a Ford cal, but using the wrong identifier. The cal should show up as 8U7A-14C204-JD. That being said, they may use the cal ID instead of the actual calibration part number to prevent IDS from automatically updating the calibration. That Tuned PCM Cal changes up to teartag identifier KRU3, which is a 50-state automatic calibration, and KRU3 (your A0533 cal, JD suffix) or KRU4 (A0534, JE suffix) is the teartag I am seeing most commonly identified by the IDS or any tool capable of pulling the Cal ID, in respect to tuned trucks. Quote Link to comment Share on other sites More sharing options...
Aaron Posted May 18, 2013 Share Posted May 18, 2013 As for knowing the suffixes, I've painstakingly compiled a tear tag list for the 6.4 trucks, and I'm working on one for the 6.7 trucks as well. Quote Link to comment Share on other sites More sharing options...
