Electrical Part Numbers
Keith Browning
This is a list of hard to find and oddball electrical parts that are good to have on hand. If you have numbers you would like to add to this list or see any part of this list that is incorrect or requires updating because the part number has been changed please PM me with the information and I will add it to the list.
[td]6.0L Fuel Injector Connector Retainer Clip
Part # Motorcraft # Part Description
1F1Z-14489-AA COP Hardshell Connector
3U2Z-14S411-BXAB WPT-984 EGT Sensor harness connector 6.7L
3U2Z-14S411-LKA WPT-615 16-pin DLC connector
6E7Z-12A690-DA   6.0L IPR Valve/VGT Actuator Connector Pigtail Kit
E8TZ-9S283-A   7.3L Fuel Filter Restriction Sensor
4C3Z-12B568-AA   GPCM harness connector kit 7.3L, 6.0L & 6.4L
1U2Z-14S411-AKB WPT-1136 6.0L Fan Clutch connector on ENGINE HARNESS
3C3Z 14A099-AA   6.0L F-series under hood wiring harness support
2C3Z-14A163-AB   UVC harness clips 7.3L
W301557   Battery cable stud @ left valve cover 2004 Econoline 6.0L
5C3Z-14A411-A   6.0L EGR Valve Harness Pigtail
FU2Z-14S411-YA WPT-1436 ECT/EOT Pigtail for 6.0L and 6.4L
4C3Z-9g609-AA   6.0L IPR Wrap Around Heat Shield
3C3Z-12224-BA   ICP/EBP connector minus the nyogel
3U2Z-14S411-BXAB   6.7L EGT Harness Pigtail
W301222
This topic is now closed to further replies.
