mchan68 Posted June 5, 2013 Share Posted June 5, 2013 I have an '11 E-350 V10 gasser here that I short blocked about a year ago at 24,000 kms. with five out of ten cylinders with spun rod bearings. It's now back at 48,000 kms. with a spun cylinder #2 only rod bearing. The rest of the nine cylinders' rod bearings are undamaged. This engine looks otherwise clean inside and out. Is there anything I should be doing to prevent yet another issue inside the engine another 24,000 kms. later? I really don't feel like RE & REing the engine in this thing for warranty times being it's an E-Series. Quote Link to comment Share on other sites More sharing options...
Alex Bruene Posted June 6, 2013 Share Posted June 6, 2013 Now, now... E-Series gas engines are a breeze to remove. I think the new V-8s and V-10s are junk. We have a few 5.4 Econolines running around that have had multiple engine replacements. No V-10s, mind you, but there are enough similarities. How many oil changes has it had in the last 24K? Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted June 6, 2013 Share Posted June 6, 2013 Motorcraft filters? Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted June 6, 2013 Share Posted June 6, 2013 We went through a period of 2009-2011 engines in trucks/vans that were all knocking. All of them either had very low oil or went op to 40,000 without an oil change. I recall mt FSE stating Ford suspected PCV valves were responsible but I don't think anything was ever officially said about it or materialized. There is an SSM out there advising you to be sure to install a PCV valve in long block assemblies as one might not be there... or something to that affect. Quote Link to comment Share on other sites More sharing options...
paulbud Posted June 8, 2013 Share Posted June 8, 2013 I thought I saw a ssm or tsb for valve seals and oil consumtion .if no one checks oil between services could be running low on oil.most of the ones we been seeing are serviced right before there dropped off with a knock. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted June 10, 2013 Share Posted June 10, 2013 There is a superceeded TSB now... see TSB 13-6-9. Quote Link to comment Share on other sites More sharing options...
