2001 F450
ETS
I wonder if someone out there would be kind enough to run an Oasis Report on a truck I just purchased for working around the farm.
2001 F450 1FDXF46S41EB25161. Origionally sold in Penn.  2WD, V-10, 5Spd. 165WB.
  Thanks In Advance!
Mr. Browning,
 Wanted build specifications and window sticker information more than anything.  Options, Axle Specs, Gear Ratio 4.88?, Limited Slip?,  Decode Door Sticker,  Etc. Etc.
  Any Major Repairs?  What is 05S28?   150K now, Runs like a watch.
Thanks Again,
  • Like 1
4.88 limited slip rear axle, 15,000lbs GVW  5400 lbs front axle, 11,000lb rear axle, 49 state emissions. Looking at the oasis info, looks like a plain jane work truck.  05S28 is the speed control recall. A fused jumper harness is installed between the cruise deactivation switch on the brake master cylinder and wiring harness to prevent a "thermal event".
