PowerSToKed Posted July 25, 2013 Share Posted July 25, 2013 I replaced Head Gaskets, EGR cooler, oil cooler, flushed cooling system, added new coolant and replaced the radiator about a month ago, since then the customer has complained about the air intermittently blowing hot. I have not been able to very the concern but he says it will start blowing hot sometimes at idle or while driving at speeds below 60 mph and come and go, he says it does fine at speeds above 65. I replaced the fan clutch and checked A/C pressures - concern still present. Any ides on what else could cause a concern like this? Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted July 25, 2013 Share Posted July 25, 2013 Had a few like that with pin fit issues at the compressor clutch. Not sure if tugging on the wiring harness while making repairs to the engine caused it or not. I just close the two pins up a little tighter and she's G to the G (good to go). 1 Quote Link to comment Share on other sites More sharing options...
PowerSToKed Posted July 25, 2013 Author Share Posted July 25, 2013 I will definitely try that!!! Thanks for the info Quote Link to comment Share on other sites More sharing options...
mchan68 Posted July 25, 2013 Share Posted July 25, 2013 Well, EVER SINCE you replaced my head gaskets ........ 1 Quote Link to comment Share on other sites More sharing options...
PowerSToKed Posted July 26, 2013 Author Share Posted July 26, 2013 10-4, gotta love Mr & Mrs Eversince Quote Link to comment Share on other sites More sharing options...
Aaron Posted July 28, 2013 Share Posted July 28, 2013 Clutch gap on the wide end of spec maybe? Quote Link to comment Share on other sites More sharing options...
Jim Warman Posted July 29, 2013 Share Posted July 29, 2013 Clutch gap on the wide end of spec maybe? +1 Quote Link to comment Share on other sites More sharing options...
