mchan68 Posted August 8, 2013 Share Posted August 8, 2013 What is the difference between GL-8697-RM and GL-8698-RM ? (Other than one number before the smart asses answer) Quote Link to comment Share on other sites More sharing options...
Aaron Posted August 9, 2013 Share Posted August 9, 2013 Ahem. "1". No charge. Your pal, Captain Obvious Quote Link to comment Share on other sites More sharing options...
Aaron Posted August 9, 2013 Share Posted August 9, 2013 In all honesty, I can't seem to locate a difference anywhere online. The parts room can't give you applications? Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted August 9, 2013 Share Posted August 9, 2013 GL-8697-RM, 6C3Z-10346-DBRM is a single alt 110 amp GL-8698-RM, 6C3Z-10346-BBRM is a upper dual alt 140 amp Both mount on the intake manifold and are interchangable for 05+ f-series. I run the 140 amp alt on my truck. Stole it off ebay and it had the original box so I got a $75 core refund. Quote Link to comment Share on other sites More sharing options...
mchan68 Posted August 9, 2013 Author Share Posted August 9, 2013 GL-8697-RM, 6C3Z-10346-DBRM is a single alt 110 amp GL-8698-RM, 6C3Z-10346-BBRM is a upper dual alt 140 amp Both mount on the intake manifold and are interchangable for 05+ f-series. I run the 140 amp alt on my truck. Stole it off ebay and it had the original box so I got a $75 core refund. THANK YOU!!! That was the answer I was looking for. I just replaced an alternator on an '06 F-550. It listed the GL-8697-RM number. This alternator looked peculiarly larger than the one on my '07, so I looked up the part number on mine, and came up with GL-8698-RM. So you're telling me the F-550 uses a smaller 110 amp alternator than my '07 F-250's 140 amp? Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted August 9, 2013 Share Posted August 9, 2013 Hmmm well I don't know now. I took a 110 off mine and thought I was putting on a 140. Honestly I didn't notice any size difference. The one I put on mine though was not a reman and was a left over brand new unit. Does your truck have dual alternators or any kind of package that would equip it with a single 140 amp? I always assumed the 140 was just for trucks with dual alts. Perhaps a Lariat or a truck with a lot of accessories would have a single 140. My truck is an XLT with very few options. OR what else is possible is the one in my 140 amp box was not a 140. Quote Link to comment Share on other sites More sharing options...
mchan68 Posted August 9, 2013 Author Share Posted August 9, 2013 Mine is only an XLT equipped with a single alternator. Quote Link to comment Share on other sites More sharing options...
Aaron Posted August 9, 2013 Share Posted August 9, 2013 Install the big 6.4 alternator. 200 Amp IIRC. You need to machine the case a little around the heater tube bolt but it works pretty well. Did it on a couple conversion vans. Quote Link to comment Share on other sites More sharing options...
Chase Posted April 16, 2014 Share Posted April 16, 2014 Like a GLV 8654 RM? The alt on my excursion just crapped out, wanting to upgrade, but would like factory parts if possible. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted April 16, 2014 Share Posted April 16, 2014 Since this post I've been told there are several packages that will equip a 6.0 truck with a 140 amp alt from the factory. The main notable one being the snow plow package. Quote Link to comment Share on other sites More sharing options...
Chase Posted April 16, 2014 Share Posted April 16, 2014 I was actually referring to the 6.4 alternator Aaron had suggested. Got one sitting in front of me, not all that different. I'm thinking of going for it. Quote Link to comment Share on other sites More sharing options...
Chase Posted April 20, 2014 Share Posted April 20, 2014 Well, 6.4 200 amp alternator is on and functioning, just need to grind away the case to bolt the heater tube back on. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted April 20, 2014 Share Posted April 20, 2014 What kind of voltage is it putting out at idle? Edi t- Damn it now I want a 6.4 alt. Quote Link to comment Share on other sites More sharing options...
Aaron Posted April 21, 2014 Share Posted April 21, 2014 I took an aftermarket unit with an external controller on it off, and put a 6.4 200a on. It was on a shuttle bus. Run 13.1 at idle with all the roof air, lights, wipers and blower fans on "let 'er eat" setting. Quote Link to comment Share on other sites More sharing options...
Chase Posted April 21, 2014 Share Posted April 21, 2014 MIne was doing 13.5 @ hot idle, when I started it for the first time, voltage started climbing instantly instead of the minute and a half wait with the factory one. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted April 22, 2014 Share Posted April 22, 2014 What did it climb to? Voltage set point? Mine idles 14.0v all day with the 140amp 6.0 alt Quote Link to comment Share on other sites More sharing options...
Chase Posted April 22, 2014 Share Posted April 22, 2014 It slowly climbed to 13.3-13.5v. MInd you I have an 05 Limited Excursion, lots of electrical load. Edit: I'll see what it does over time, i'm also going to install a voltmeter in the Excursion to monitor voltage. The batteries went almost dead on my wife, battery light never came on. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted July 20, 2014 Share Posted July 20, 2014 Snagged a new 6.4 alt on eBay to try out. Took some comparison pics Quote Link to comment Share on other sites More sharing options...
Aaron Posted July 20, 2014 Share Posted July 20, 2014 Shit, I don't remember having to take that much off. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted July 20, 2014 Share Posted July 20, 2014 Doesn't matter, this alternator won't work correctly on a 6.0 anyways. The 6.4 uses a PCM controlled system 4 charging system, this means a GENCOM line to control voltage set point based on what the PCM wants. This is why Chase's alt only charges 13.5v, it's self exciting basically in default mode. A little digging in the WSM saved me some time Quote Link to comment Share on other sites More sharing options...
Aaron Posted July 22, 2014 Share Posted July 22, 2014 The one I put on seemed able to keep up but this is going back a bunch of years. Quote Link to comment Share on other sites More sharing options...
