lmorris Posted August 26, 2013 Share Posted August 26, 2013 I have an F550 that needs a short block due to a dead miss with excessive blow-by and low compression on one hole. I haven't torn into it yet but I suspect a melted piston, mainly because of the rhythmic puffing coming from the oil filler. Another Ford dealer told the owner that a failed head gasket will damage injectors which in turn melt the piston. Has anyone ever heard of this before? Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted August 26, 2013 Share Posted August 26, 2013 I have yet to see a bad head gasket in a 6.4L but I have seen a lot of fuel injectors go bad, usually from fuel quality issues. How will a bad HG cause an injector failure anyhow? Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted August 27, 2013 Share Posted August 27, 2013 which hole if you don't mind me asking? Quote Link to comment Share on other sites More sharing options...
Mikill Posted August 29, 2013 Share Posted August 29, 2013 Headgasket failure would not cause this. I only seen one head gasket failure on a 6.4 by the way. More than likely overfueling injector melted piston which was probably caused by overfilled crankcase. I haven't seen one in a couple years but I'm sure it still happens. Quote Link to comment Share on other sites More sharing options...
lmorris Posted August 29, 2013 Author Share Posted August 29, 2013 I haven't gotten into this one too much yet. It doesn't smoke when running, just has the dead miss, forget what cylinder but will update when the engine gets in. The oil level is normal, but the oil condition is not good. I am really questioning the the whole head gasket failure though, maybe that is why the truck came here instead of being fixed by the dealership that it first went to. Quote Link to comment Share on other sites More sharing options...
lmorris Posted September 4, 2013 Author Share Posted September 4, 2013 As you can see #8 is suffering from a major case of "broken". Head looks good, rocker tips are worn. Injector tip and glow plug look good, but I will be replacing both on #8. Any ideas,other that a leaking injector, that may cause this? Quote Link to comment Share on other sites More sharing options...
mchan68 Posted September 4, 2013 Share Posted September 4, 2013 As you can see #8 is suffering from a major case of "broken". Head looks good, rocker tips are worn. Injector tip and glow plug look good, but I will be replacing both on #8. Any ideas,other that a leaking injector, that may cause this? The last one I had, cylinder #8 connecting rod was 's' shaped, likely due to the obvious horizontal cooler failure that one had also suffered. It sure put a nice deep gouge on the cylinder wall as well. Quote Link to comment Share on other sites More sharing options...
lmorris Posted September 4, 2013 Author Share Posted September 4, 2013 Coolers are good on this one. Piston is above deck height, but not as much as it should be. Most likely wrist pin holes in piston are damaged. Cylinder wall is scored on the side where the piston has the big hole.Very little metal in the pan, other than the piston pieces. I am hoping it was an injector issue. Most fluid ingestions end up with the most common bent rod and not this type of failure. Quote Link to comment Share on other sites More sharing options...
Aaron Posted September 6, 2013 Share Posted September 6, 2013 Brad had a really good picture of protrusion to identify a bent rod before removal of the rod/piston assembly. I think it's on his photo post on this site. Look under Brad Clayton Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted September 7, 2013 Share Posted September 7, 2013 Quote Link to comment Share on other sites More sharing options...
Aaron Posted September 7, 2013 Share Posted September 7, 2013 Thanks B-rad! Quote Link to comment Share on other sites More sharing options...
