duff Posted September 25, 2013 Share Posted September 25, 2013 I have a 1992 e-van non turbo under hard accel. vehicle will start to knock - missfire - heavy smoke blueish in color - after coming to a stop smoke will stop and motor starts to smooth out -runs fine at normal driving. fuel pressure at filter adapter 4-5 psi idle raise rpm drops 1-2 psi - return line has 1-2 psi at 2500 rpm - attempted to crack fuel lines at injectors to find missfire they all seem to drop same rpm and good fuel flow -- during idle - any ideas for further testing possibly fuel pick up intank plugged ? thanks Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted September 25, 2013 Share Posted September 25, 2013 Them things can suck air, you can bypass the chassis and just run a jug of diesel fuel to the lift pump and see what happens as long as test results are valid in your bay. Sounds like you could also have a leaking injector tip. You need the old school injector tester to check them accurately though. oddly enough we have two of them. Our shop is a living museum. http://www.toolsource.com/nozlrater-diesel-fuel-injector-nozzle-tester-d93l9000a-p-62578.html?osCsid=9m6tib3f203feg3qp60snjfq00 Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted September 25, 2013 Share Posted September 25, 2013 When in doubt on these old ass engines.......run a manual compression test. It can give you volumes of information on the state of health before going any further. Quote Link to comment Share on other sites More sharing options...
Mekanik Posted October 2, 2013 Share Posted October 2, 2013 I used to install a clear hose at the injector pump spliced into the return line. If the fuel system is sucking in air, you'll see it there. 1 Quote Link to comment Share on other sites More sharing options...
duff Posted October 15, 2013 Author Share Posted October 15, 2013 ALL EIGHT INJECTORS HAVE BEEN REPLACED - INJ. PUMP REPL. - RUNS FINE AROUND TOWN - AT HIGHWAY SPEEDS STARTS TO RUN ROUGH SMOKE HEAVILY LET OFF ACCEL. AND SLOW DOWN CLEARS OUT AND SOME ROUGHNESS Quote Link to comment Share on other sites More sharing options...
Aaron Posted October 15, 2013 Share Posted October 15, 2013 What's your fuel pressure at highway speed, how about volume? Clear hose on the pump return side to look for bubbles? Inlet restriction on the feed side, with the motor running at the governor? Quote Link to comment Share on other sites More sharing options...
