2006 Explorer cruise bulb
amailloux
I may have been wrong on that year model, I can't remember now. I know the newer ones are led's. From the work shop manual:
Q4  CHECK FOR CORRECT INSTRUMENT CLUSTER OPERATION
    [*]Disconnect the instrument cluster connector.
    [*]Check for:
      [*]speed control bulb [*]corrosion [*]pushed-out pins
    [*]Connect the instrument cluster connector and make sure it seats correctly.
    [*]Operate the system and verify the concern is still present.
They passed on a 450 dollar cluster. Did go for a new solenoid pack for the trans though.
Thanks.
I guess that means this truck is equipped with the 4.0L SOHC (which is backed by the 5R55S with the troublesome solenoid packs), as opposed to the 4.6L 3-valve (backed by the 6R60).
Yep.  Had 0 rpm drop.  I could command the solenoid, and hear it click also.  I dropped the pack and used a short piece of hose and
my lungs to determine it can not allow pressure.  After hearing the solenoid click I thought a new converter or stuck valve was going
to be at fault.
