Brad Clayton Posted November 26, 2013 Share Posted November 26, 2013 Nov 22 2013 4358 -2013-2014 Fusion/Escape - 1.5L, 1.6L GTDI and 2.0L GTDI oil capacities EcoBoost badging is common on vehicles equipped with a 1.5L GTDI, 1.6L GTDI or 2.0L GTDI engine. However, oil service fill capacities are different. Engine size can be identified from under the vehicle during an oil change by observing the oil filter orientation. The filter on a 1.5L and 1.6L is mounted horizontally; a 2.0L filter hangs vertically. Owners Manual and Motorcraft information on engine oil capacity (including oil filter) is correct. The 1.5L and 1.6L utilize 4.3 qt (4.1 L), the 2.0L holds 5.7 qt (5.4 L). Always fill each engine with the correct amount of oil. Here's am idea, how about commonizing the oil capacities or at least design the friggin' pans to hold a number that is rounded up to halfs or full quarts. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted November 26, 2013 Share Posted November 26, 2013 Never gonna happen. Put 15 quarts in any Power Stroke and it will be over full. There are other examples. Not sure why anyone would be suprised by this. Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted November 26, 2013 Author Share Posted November 26, 2013 I am not surprised........just frustrated. You have 3 small four cylinder engines that are extremely close in displacement yet take different capacities and can't run a simple 4 quart or 5 quart oil pan. Quote Link to comment Share on other sites More sharing options...
lmorris Posted November 26, 2013 Share Posted November 26, 2013 We had this same discussion here at the shop yesturday...weird. I remember when a 4 cylinder took 4 litres, a V6 took 4.5 litres and everthing else took 5 litres. Quote Link to comment Share on other sites More sharing options...
mchan68 Posted November 26, 2013 Share Posted November 26, 2013 We had this same discussion here at the shop yesturday...weird. I remember when a 4 cylinder took 4 litres, a V6 took 4.5 litres and everthing else took 5 litres. That sounds like all the GM engines of the 80s and 90s era. Quote Link to comment Share on other sites More sharing options...
lmorris Posted November 27, 2013 Share Posted November 27, 2013 We had this same discussion here at the shop yesturday...weird. I remember when a 4 cylinder took 4 litres, a V6 took 4.5 litres and everthing else took 5 litres. That sounds like all the GM engines of the 80s and 90s era. Yup, worked at Canadian Tire and Midas during my pre-apprentice days from 88-91 Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted November 28, 2013 Share Posted November 28, 2013 I thought I was the only one who put 14.5qts in a 6.0 or 6.4 Quote Link to comment Share on other sites More sharing options...
mchan68 Posted November 28, 2013 Share Posted November 28, 2013 We had this same discussion here at the shop yesturday...weird. I remember when a 4 cylinder took 4 litres, a V6 took 4.5 litres and everthing else took 5 litres. That sounds like all the GM engines of the 80s and 90s era. Yup, worked at Canadian Tire and Midas during my pre-apprentice days from 88-91 Yup. And did you happen to notice Fords always seemed to take more oil I guess because most of that era took the FL-1A filters that would hold one litre alone? Quote Link to comment Share on other sites More sharing options...
Aaron Posted November 28, 2013 Share Posted November 28, 2013 I put like 12.5 in mine so I cab make sure it's not growing oil. Quote Link to comment Share on other sites More sharing options...
