Autoworker Posted November 26, 2013 Share Posted November 26, 2013 I have a 2013 c max from usa with no dlr programed in the bcm the manual said NOTE: The DRL is a programmable parameter for this vehicle. but with ids cannot find a way .should I be able to program bcm with a as built date from a Canadian Vehicle that has the dlr . DOES ANY ONE HAVE A IDEA HELP PLS Quote Link to comment Share on other sites More sharing options...
Aaron Posted November 26, 2013 Share Posted November 26, 2013 Contact hotline with RIV number and say you need modified as built to turn DRL on. Quote Link to comment Share on other sites More sharing options...
Autoworker Posted November 26, 2013 Author Share Posted November 26, 2013 Comment From: Ford Comment Date: 11/25/2013 12:14:20 PMTerry,At this time there is not a supported procedure to enable the DRL's on this vehicle through the BCM.It is recommended to seek alternative options to install DRL's on this vehicle. Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted November 26, 2013 Share Posted November 26, 2013 I call SHIT OF THE BULL!!! Quote Link to comment Share on other sites More sharing options...
Aaron Posted November 26, 2013 Share Posted November 26, 2013 That's horse shit. There's Canadian vehicles that would have had to have DRL on em. Quote Link to comment Share on other sites More sharing options...
Autoworker Posted November 26, 2013 Author Share Posted November 26, 2013 I agree but with out the build dates im screwed .don't no why its so top secret .we did some mustang GT build date and worked Quote Link to comment Share on other sites More sharing options...
Cetane Posted November 26, 2013 Share Posted November 26, 2013 Be careful programming it with the as built from another vehicle. If the option content isn't exactly the same you could run into problems. PM me the VIN and I will look into it tomorrow. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted November 26, 2013 Share Posted November 26, 2013 I was able to enable the DRL on my 2007 Freestyle by using the IDS special functions menu with the "code of the day" password. Quote Link to comment Share on other sites More sharing options...
Aaron Posted November 27, 2013 Share Posted November 27, 2013 Most of the code of the day stuff doesn't work anymore. 1 Quote Link to comment Share on other sites More sharing options...
Cetane Posted November 28, 2013 Share Posted November 28, 2013 The as built on these cars doesn't have the ability to change the DRL setting. It is possible through other methods but it looks like IDS doesn't have the ability to enable it. Maybe it is a feature that is coming....... Quote Link to comment Share on other sites More sharing options...
Aaron Posted November 29, 2013 Share Posted November 29, 2013 Wow, that's nuts. What about units sold in Canada? Or are they having to generate new asbuilt like they did at first with the new body style mustangs? Quote Link to comment Share on other sites More sharing options...
Cetane Posted November 29, 2013 Share Posted November 29, 2013 I was being purposefully nondescriptive because I don't know why IDS won't reconfigure the options correctly. I ended up emulating that vehicle with IDS. It looks like the option exists and it will let you select the change but apparently it doesn't properly execute the command. It might be on purpose or maybe the program has some bugs. As built in the way you are traditionally used to using it doesn't really apply in this case. It is more like flashing a new cal. Once/If IDS starts doing it correctly it will probably be transparent to the average user but it is much more complex(in this case). You probably won't be able to grab a VIN from a similar vehicle and use that "as built" data like some of you have been doing. I don't know what you are referring to with the Mustangs but as far as I know, the correct data is being generated for Canadian bound vehicles. The problem only appears when you try to change one of those options after the fact with IDS. Quote Link to comment Share on other sites More sharing options...
Aaron Posted November 29, 2013 Share Posted November 29, 2013 We were buying a lot of 05ish mustangs at the dealer I was at from the USA. We'd put in a hotline contact and they would send us revised as built data with DRL enabled as long as you sent them the RIV number, as the option wasn't "enable disable" in IDS like some models are. I think it's done that way with a toggle now. As opposed to having to totally reconfigure the module. Quote Link to comment Share on other sites More sharing options...
