gengor Posted January 7, 2014 Share Posted January 7, 2014 I got here a 6.7 with no brakes, I found that the brake booster failed. once I started ripping it apart I found oil throughout the vacuum system, all the lines are just full, the vacuum can is full as well, the only possible place for that oil to come from that I think is a failed vacuum pump. Has anyone seen this yet?? Quote Link to comment Share on other sites More sharing options...
lmorris Posted January 8, 2014 Share Posted January 8, 2014 Yup, we see a lot. The vacuum pump is oil lubed. So when they fail the systems gets pumped full of oil. You have to replace all the lines and the vacuum canister/battery tray/degas bottle if oil makes it to the cannister. Quote Link to comment Share on other sites More sharing options...
jimmy57 Posted January 8, 2014 Share Posted January 8, 2014 Those 250's REALLY want HydroBoost don't they? Quote Link to comment Share on other sites More sharing options...
gengor Posted January 8, 2014 Author Share Posted January 8, 2014 upon closer inspection I found oil everywhere, even the wastegate actuator is full!!! this one is getting a complete system replacement!@! thanks guys!! Quote Link to comment Share on other sites More sharing options...
