FordFanaticTony Posted January 15, 2014 Share Posted January 15, 2014 I have a 2008 6.4 needing a oil cooler and I am tired of pulling cabs. Any help would be appreciated. I can imagine the turbos being a pain to pull cab on. Quote Link to comment Share on other sites More sharing options...
amailloux Posted January 15, 2014 Share Posted January 15, 2014 I do them all cab on. If there is no rack, or body attached to the cab then you can do a partial lift and put 4x4 blocks under the front mounts. If you do a search, there is a post on oil cooler replacement and 1 for partial cab lift. Quote Link to comment Share on other sites More sharing options...
FordFanaticTony Posted January 15, 2014 Author Share Posted January 15, 2014 Cool thank you. Turbos and pedestal still must come out right? Quote Link to comment Share on other sites More sharing options...
lmorris Posted January 15, 2014 Share Posted January 15, 2014 Yes. Quote Link to comment Share on other sites More sharing options...
FordFanaticTony Posted January 15, 2014 Author Share Posted January 15, 2014 Thanks for the help. Have to try it once. Quote Link to comment Share on other sites More sharing options...
Chase Posted January 20, 2014 Share Posted January 20, 2014 I do them all cab on. If there is no rack, or body attached to the cab then you can do a partial lift and put 4x4 blocks under the front mounts. If you do a search, there is a post on oil cooler replacement and 1 for partial cab lift. I do the same thing. Not enough lifts to go around here. Easier I think anyways. Quote Link to comment Share on other sites More sharing options...
