robp823 Posted January 18, 2014 Share Posted January 18, 2014 Anyone know what they use for the injector disable test???? Do the add up the fuel rates then divide by 6? Then whatever is below the average is suspect?Servicemaxx gives very vague instruction.It tells you to run the engine at normal idle.Then disable for 10 seconds and run normal for 10 seconds for each injector .Then displays engine load,fuel rate and rpm results for each cylinder.Is there a formula? Quote Link to comment Share on other sites More sharing options...
Bruce Amacker Posted January 18, 2014 Share Posted January 18, 2014 Yes, basically divide by 6 for your average. I have a PDF of known good and bad, I'll split it out and post it here tomorrow. You work at a IH dealer, right? Don't you have access to a CPT that plugs in to the CMP and CKP? Quote Link to comment Share on other sites More sharing options...
robp823 Posted January 18, 2014 Author Share Posted January 18, 2014 Yes I do.But shit like this like to know.I think it's cool .I would appreciate the post. Quote Link to comment Share on other sites More sharing options...
Bruce Amacker Posted January 18, 2014 Share Posted January 18, 2014 Try this. Servicemaxx Fuel Rate cyl diag.pdfFetching info... 1 Quote Link to comment Share on other sites More sharing options...
robp823 Posted January 18, 2014 Author Share Posted January 18, 2014 Bruce you are the man!Many thanks.What other cool stuff you got hahaha. Quote Link to comment Share on other sites More sharing options...
