dieseldoc Posted January 29, 2014 Share Posted January 29, 2014 Anybody heard of or found the fuel additive being used causing the major failure of a 6.7? I have a friend who works for a large fleet and they have had 2 trucks with major engine failures in the last couple weeks. Both trucks had low miles on them. They have been using power service fuel additive specifically rescue 911. There dealership has told them that ford says that additive can not be used and that is what is causing the failures. Just curious if any of you guys have come across this situation or information from ford. The additive says it is rated for ulsd use. Sounds odd to me but I can see it being possible I suppose. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted January 29, 2014 Share Posted January 29, 2014 I don't see how. Diesel 911 is not a regular additive and is intended to be used in cases where the fuel system is already waxed and frozen up. It does contain lubricants and such so I can't see it being harmful to be honest. What I would like to know is what was the root cause of the two engine failures before even attempting to make an kind of a link to the fuel or the use of additives. Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted January 29, 2014 Share Posted January 29, 2014 Sounds like spun bearings again. Quote Link to comment Share on other sites More sharing options...
Alex Bruene Posted January 29, 2014 Share Posted January 29, 2014 There is a new fuel additive that has been on the market for the last 3 or 4 years called "DEF" that's been causing a few issues! Quote Link to comment Share on other sites More sharing options...
batmantech Posted January 29, 2014 Share Posted January 29, 2014 Hotline told me to code it to the bearings, that sounds to me like spun bearings on the 2011 engine builds is an issue. Not the result of anything causing it. Quote Link to comment Share on other sites More sharing options...
Aaron Posted January 29, 2014 Share Posted January 29, 2014 Rescue 911 is basically kerosene and methyl hydrate isn't it? Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted January 30, 2014 Share Posted January 30, 2014 Diesel 911 has butanol in it, butyl alcohol. That's the only ingredient I noticed that was suspect. We all know alcohol is an emulsifier. Most of the other ingredients are generally found in other diesel additives, xylene is the only other unusual one I've noticed that power service uses in all their additives. Quote Link to comment Share on other sites More sharing options...
Bruce Amacker Posted January 30, 2014 Share Posted January 30, 2014 Diesel 911 has butanol in it, butyl alcohol. That's the only ingredient I noticed that was suspect. Wow, I didn't know that, all OEMS have TSBs stating not to use alcohol in modern diesel fuel systems. I looked up the MSDS at http://www.mazergroup.ca/wp-content/uploads/2012/05/MSDS-Other-Diesel-9111.pdf and it "looks" like in Section 15 it could be as much as 30% alcohol. If it is I will definitely recommend against using this is my classes..... Quote Link to comment Share on other sites More sharing options...
dieseldoc Posted January 30, 2014 Author Share Posted January 30, 2014 We'll my buddy's truck dropped a valve, n it is n 11 model year I believe. They have another truck with spun bearings. I guess the dealer also has two others with spun bearings. I'm a lil nervous about owning one. All a guy can do is the maintenance n use good fuel n fluids I suppose. Quote Link to comment Share on other sites More sharing options...
exmod110 Posted January 30, 2014 Share Posted January 30, 2014 I can see a possable concern in the fuel system but not resulting in dropped valves or bearing problems. Now it an injector failed from these additives could cause a melted piston and go from there.... Quote Link to comment Share on other sites More sharing options...
