early build f-550 64k has ate 3 turbos in its life. Now locked up.
Got one here that has had turbo failure at 12k, 31k, and 59k. Now it's towed in at 64k with glow plug circuit codes and locked up. Those were the only codes it had in it. Got it out and cyl 5 &7 injectors damaged. I have a long block approved. Also replacing  cac, egr coolers. I am concerned about the turbo but everything seems fine with it now. Any input would be great thanks.
With the 450/550 turbo failures you must be sure to update the calibration according to the Hot-Line. Apparently the original calibrations were asking too much from the turbos. What was the root cause of the engine failure? Were you able to tear it down or did you just swap it out per the TSB?
I put the turbo in at 31k with the 12b37? recall and reprogramed it. I didnt tear down the engine any further because it fell into the tsb. Friday i go back to work and will look at turbo a little closer and probally put one one to cover my butt. Anyone having problem getting fuel injectors? parts telling me they are D99 backorder.
  On 1/30/2014 at 11:04 AM, Keith Browning said:
Injectors are indeed currently on backorder filling emergency orders only. Ordered one two days ago myself for a broken hold down bolt. I am tempted to reuse the injector.
I always reuse the injector when a hold down breaks.  I just replace the seals, tube and hold down...  And the 0.7 hour abortion when needed.
  • 4 weeks later...
  • 3 weeks later...
That was quick. Made it 2k miles and the turbo is out again. The bearing is out and compressor and exhaust wheel contacting housing, also one of the exhaust turbines broke off and went down exhaust. What could be going on here, I replaced egr coolers and cac when I installed engine.  There are no codes, maybe exhaust is plugged? causing bearing to over heat? This thing is a big pig weighs nearly 18k pounds. thanks for any info.
