Branch Tube
I'm joining the club. The few that have actually replaced a branch tube, I feel your pain. Earlier this week I diaged a hot no start with a blown out branch tube to fitting o-ring. Now I have done a lot of STCs over the years as we all have and none have ever returned with a blown out o-ring.Pull the bolts out of the tube and its apparent the pass side bolt is crossthreaded. It's tight all the way out. The pump connector is not on straight as verified with an old STC metal bracket. Someone actually ground a flat spot on the bolt threads to make it into a self tapper and ran it in. I was pretty surprised to see this honestly. This is advanced hackery.So onto the repair. Seems straight forward until you really look at the WSM and start working then you realize how screwed up it actually is. You are to pull off 5 rockers and pushrods. Easy because we've done lots of headgaskets right? Nah not as easy as it looks especially when the fulcrum ball defies gravity and stays attached to the pedestal. The rockers are out and the tips are destroyed which I hadn't anticipated.Oh well still work to do. So I grab my 10" extension and T27 and start on down. This seems a little fishy to me. Then I realize what I have is definitely too wide to work. Now what? Well in the back of my mind I can remember Jim saying one time to take your T27 and weld it to the extension. Excellent advice. I pressed the bit from my socket, fired up the TIG and proceeded to make a tool I only hope to need this one time.Sure enough it worked, the tube is out, new one in, new fitting lined up correctly and an undeserved sense of accomplishment rains down. Somehow I was actually able to stick my big head up into the tunnel, reach up around both sides of the engine to position the socket into the bolt heads. You do need to go through the pushrod holes on a pretty decent angle. Scary yes but what's scarier is that it actually works. And since its Saturday I snapped some pics.
  • Like 1
You've joined the club, so now you can enter into the secret society that bends branch tubes back into position to avoid ever replacing branch tubes again.
I'm just kidding.  If it was hacked like that I'd probably replace it too.
I'm not going to lie, the thought of a branch tube repair was always one that made me scratch my head :scratch: Likewise I love a challenge.
Now that I've done one if there is a next time I certainly won't be caught off guard.  Positioning those rockers about had me pulling my hair out in clumps
I can relate.  I just got done replacing all rocker arms in a 6.0L.
I've done one branch tube in the WSM method. Now, I remove the heads.
8/10 of them probably could use head gaskets anyhow. The other two already had head gaskets done. Lol
You know, Heli-coiling that bolt hole does not look all that bad of an idea considering all of the work and aggravation involved in replacing an otherwise good branch tube. Of course the utmost care in preventing debris from getting into the engine must be taken... Call me crazy if you want to.
