Brad Clayton Posted February 13, 2014 Share Posted February 13, 2014 Kinda slow and reviewing things we need to know, found this interesting: WHAT’S NEW IN 2014?· Powertrain Control Modules (PCM) removed from Prior Approval.· The Diesel Exhaust Fluid (DEF) Pump and Heater/Sender Assembly added to Prior Approval.· New 6.7L High Pressure Fuel System Kit (containing High Pressure Pump) added to Prior Approval.· Image requirement for 6.4L and 6.7L Diesel High Pressure Pump Prior Approval.· All dealers require Prior Approval for Shelby GT500 Engine Assemblies – including on-site inspection by a Ford representative.· Image requirement for Gas Engine Assembly Prior Approval. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted February 13, 2014 Share Posted February 13, 2014 Thank you Mr. Brad - I just ordered a DEF heater for TSB 13-10-5. Guess I had better click on the prior-approval tab... Quote Link to comment Share on other sites More sharing options...
lmorris Posted February 13, 2014 Share Posted February 13, 2014 Yes thank-you. Any idea when this came into play? We had a few in the last few days tha recieved DEF pumps. Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted February 13, 2014 Author Share Posted February 13, 2014 The document shows an effective date of Feb 1st, but I'm sure there is a grace period. Quote Link to comment Share on other sites More sharing options...
Fordracer Posted February 16, 2014 Share Posted February 16, 2014 I ordered a def heater/sender assembly a couple weeks ago and they said it would be the middle of March or later before we get one. Quote Link to comment Share on other sites More sharing options...
batmantech Posted March 3, 2014 Share Posted March 3, 2014 The Part coverage is not what I would have thought. This 2011 with 62,000 and the 5J225 reductant assy. is not covered. Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted August 21, 2014 Author Share Posted August 21, 2014 This clears up a little confusion on TSB 13-10-5 and prior approval. The following parts have been removed from the 2014 Prior Approval Program: Base Part Number _ _51070 Rail Assembly Roof Sliding Panel on 2013‐2014 F‐150 only Base Part Number _ _ 06024 Glove Box Door & Center Console Lid on Flex only Base Part Numbers_ _ 29710 and _ _ 29711 Glass Quarter Window (Right and Left) on 2013‐ 2014 Fusion only Base Part Number 5J225 6.7L Reductant Heater Assembly as directed by TSB 13‐10‐5 only. 1 Quote Link to comment Share on other sites More sharing options...
