batmantech Posted February 14, 2014 Share Posted February 14, 2014 This 09 came in tow from another indy shop. Cranks no start. Found right hand cam not moving, phaser turning ,pin inside broken and damaged the cam. Cam caps look good. Oil had loads of moisture milky, actual water ran out when I cracked the drain plug open. Outside temps have been around and below 0 degrees for weeks, suspect that this thing was never warmed up and froze. Wondering if anyone has seen this issue before. Basically trying to cover myself. Owner is relative of the new service writer here and just recently bought it, he keeps looking at me funny when I tell him it needs a new engine. Having hard time thinking a new phaser and cam is the answer here. Any Ideas? Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted February 14, 2014 Share Posted February 14, 2014 Interference engine, no need to plead your case any further to the owner. Engine rotating + cam not rotating = mangled parts deep inside. Quote Link to comment Share on other sites More sharing options...
batmantech Posted February 14, 2014 Author Share Posted February 14, 2014 I tried to tell people here that but I could not find that in the shop manual. I just got back my hotline response that it is not a free wheeling engine now they believe me. Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted February 15, 2014 Share Posted February 15, 2014 NOTICE: The camshaft procedure must be followed exactly or damage to the valves and pistons will result. This is from the shop manual under camshaft R&R. This is as close as I could find to Ford saying "interference" without saying "interference". Show them these photos of a 2 valve that was only 3 teeth out of time, that'll shut em up. http://www.forddoctorsdts.com/topic/3316-the-perfect-storm/ Quote Link to comment Share on other sites More sharing options...
Jim Warman Posted February 15, 2014 Share Posted February 15, 2014 Used to be a rule of thumb on OHC Fords - timing belt = OK - timing chain = bring yer wallet. Now... a 5 year old pick up. How much is it worth? About as much as a rebuilt motor? Often I get a chuckle when someone puts 5 grand into a clunker and that makes it worth almost 4 grand. Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted February 16, 2014 Share Posted February 16, 2014 ROFL Quote Link to comment Share on other sites More sharing options...
YukonTyler Posted February 16, 2014 Share Posted February 16, 2014 Last year I had a 3v 5.4 come in with a complaint of 'running rough'. Fire it up and sure enough it is not well. Check engine light is on - scan and find codes for bank 1 cam sensor. Pulled the sensor and found a big ball of copper at the tip. Pulled the r/front valve cover and found the chain, chunks of a guide and the phaser all piled up. The bolt for that phaser was nowhere to be found. The darn thing drove in on one bank which I thought was pretty impressive. I quoted an engine, it got towed away and I never saw it again. Quote Link to comment Share on other sites More sharing options...
batmantech Posted February 17, 2014 Author Share Posted February 17, 2014 Jim that is the rule of thumb that I generally stick with also. Needed something in print to satisfy some people. Those repairs to add up big numbers fast. Quote Link to comment Share on other sites More sharing options...
cbriggs Posted March 7, 2014 Share Posted March 7, 2014 I recently had a 2010 5.4l f-150 come in, super low mileage, around 20,000km if I remember right. It was stalling and surging, had cam timing codes and bank 1 vct err pid was steady at -45`. I was able to command vct and correct the timing, so I knew vct was operating, narrowed it down to base timing. It also had super milky oil, and about 3/4L of water came out of the plug before the oil when I drained it. Tore it down and found the vct phaser had turned slightly on the end of the cam and half torn the lineup pin thru the vct phaser itself. There was also evidence of the same failure on the lh cam and phaser, but not bad enough to flag timing codes yet. The phaser bolts were tight, but both phasers fell to pieces when I unbolted them from the cams. The cam journals in the heads were perfect, but all the cam lobes and roller followers were scored. When the concern happened it was about -30`c out, he said he fired it up, it had a hard time starting, then when it did after running for around 15 seconds the low oil pressure warning came up on the dash. He shut it off, restarted it 5 minutes later and it was running rough. My theory is that all the moisture in the oil froze the roller follower bearings, and when started the power needed to drive the cams nearly tore the phasers off. I think the oil was so frozen that the oil pump was unable to pull oil from the pan hence the low oil pressure light. 2 cams, phasers, all roller followers and timing chain tensioners and it is perfect. I know the customer personally, he drives the truck 2 kms, twice a day to his hardware store and back home, and that is it. He now drives the truck for a 40km journey once a week and changes his oil every 3 months... Quote Link to comment Share on other sites More sharing options...
Aaron Posted March 7, 2014 Share Posted March 7, 2014 Either that or the oil pump pickup was frozen with water. Quote Link to comment Share on other sites More sharing options...
batmantech Posted March 8, 2014 Author Share Posted March 8, 2014 We keep getting more of these with lots of water in the oil. All short trippers, this winter is been much colder than normal. Quote Link to comment Share on other sites More sharing options...
